Water in trunk, what to do b/f start attempt
Discussion in 'Newbie Forum' started by Eric Ewanco, Sep 4, 2022.
Tags:
  1. Eric Ewanco
    Eric Ewanco Junior Member
    Shrewsbury MA
    I spilled what was probably a considerable amount of water (likely a gallon or two) in my Gen 4 Prius hatch (2016). I fear at least some of it made it down to the hybrid battery compartment, but I don't know how much. Is there anything I can do before I attempt to start it to increase the chances that it will start and get me home? Or should I just try to start it and cross my fingers?
    49,490
    i would pull everything up (carpet, floorboards) and see how much has accumulated around the battery and cables.
    if there is water, you should probably open the battery case (follow precautions)
  3. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    You don't really have much to worry about. The pack is well designed to not be bothered by the usual spills and messes most cars experience... But there's always exceptions to that and you haven't explained the exact location where you spilled, nor have you detailed your efforts to clean it up. Once you elaborate we will better be able to tell you if it's safe or not?
  4. Eric Ewanco
    Shrewsbury MA
    TL;DR update: The car seems to work fine.
    The source of the water was a big food & drink cooler with melting ice with an unclosed plug that had been melting for a couple of days before I noticed it. The carpet was soaked and water could be seen pooled in the left front corner (the seats were down and the car was on a slight decline). The floorboard was a little damp but had only a few small really wet areas. When I pulled it up to expose the tire puncture repair kit, that was dry and when I forced one of those panels up, I found a completely dry but obviously sealed area where I expected the battery to be. I saw a grommet with a thin cable entering it and that was dry. I had to fish or cut bait so I tried the car and it started. So far I've driven maybe two hours with it, so I think it's ok. Thanks for the responses.
    PriusCamper and bisco like this.
  5. PriusCamper
    11,104
    4,518
    Because it's Summer things should dry out quick... If it was winter I'd offer some options to dry things out more aggressively.
  6. Mendel Leisk
    38,726
    Heat gun, wet/dry vac, leaf blower. :)
