Water keeps collecting on rear, passinger floor
Discussion in 'Gen 2 Prius Technical Discussion' started by cathcycler, Jul 19, 2008.
  1. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    The simplest cause is usually the likeliest. At some point did you have a formerly full water bottle under the seat or in a gym bag nearby?
  2. richard schumacher
    7,686
    1,068
    United States
    I keep my A/C on recirculate exclusively. Living here, if I used outside air the cabin would always be filled with vehicle exhaust. This may possibly help keep the evaporator clean; there should be little more than exhalation condensates in it.
  3. cathcycler
    cathcycler Junior Member
    gallatin, tn
    Another update...
    I went to a repair shop and they told me the rubber A/C drain tube was pushed up so water was being directed inside the car. I also found out that there was indeed plenty of water in the front seat floor, but it was underneath a pan so I didn't see it.
    Now, I have the the carpet loose so I can try to dry things out. The guy at the shop said either something bounced up and knocked it inside the car or somebody did it as a prank.
    It is not easy drying things out since we are having high humidity. It seems I will have to fight the mold & mildew monsters.
  4. richard schumacher
    7,686
    1,068
    United States
    That sucks. At least it has been fixed. Run the A/C constantly to help dry things out.
