Water pump bering making noise at idle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rich12, Jan 15, 2014.
  1. Rich12
    Rich12 Member
    176
    29
    Trying to use 10mm box-end wrench and ran into trouble freezing the pulley from turning. Also,first time messing w/ belt and pulley...working alone in a parking lot w/ no back-up. Didn't seem worth it...I could have been there all day and still not had it out.
  2. Patrick Wong
    18,214
    6,531
    1) Did you notice my post which describes how to change the engine coolant pump and shows a photo of me using a flat-blade screwdriver to hold the pump pulley stationary?
    2) Yes, if you don't have the proper facilities and tools to support your efforts, this work can be difficult.
    3) A 10 mm box-end wrench should not slip on the pulley nuts. If it did, you need to obtain better-quality tools.
    52,917
    it's good to know your limitations before you do more damage, all the best!(y)
  4. JC91006
    16,939
    8,647
    I'm hoping the dealer won't charge you more to remove the rounded off bolt heads
  5. Rich12
    Rich12 Member
    176
    29
    Nope but they wanted to sell me a new belt for $35. I'll be doing that one myself.
  6. Rich12
    Rich12 Member
    176
    29
    Yeah I didn't want to risk snapping one of those pulley machine screws off. That...would've sucked.
  7. JC91006
    16,939
    8,647
    The belt will cost you around $15, so it might be worth while to let them take care of everything for $20 more. It'll have a warranty.
    Or you may suggest to them you buy the belt at the parts counter and hand it to them. The mechanic has to remove and reinstall the belt either way. There really shouldn't be an upcharge for this belt replacement.
  8. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Too bad I didn't link to the post I wrote in Jun 13 regarding water pump replacement before you started, Rich.
    Snapping the pulley bolts wouldn't have been a big deal since you would have been replacing the water pump anyway. Snapping the bolts to the block would have been a huge PITA if a shank snapped at the block surface.
    As long as you get your water pump replaced, it's all that really matters. It won't cost you that much more.
  9. Rich12
    Rich12 Member
    176
    29
    I'd recommend anyone trying this at home to use a 10mm socket instead of fumbling with a box wrench, be prepared to deal with the idle pulley nut tightness (cheater bar) and find some way to reliably secure the pulley from turning.
