Water Pump Impeller Stuck
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusMettaFitx, Oct 1, 2023.
  1. PriusCamper
    PriusCamper Senior Member
    13,416
    5,416
    Pacific Northwest, USA
    Why can't you just go to a wrecker and get the metal plate the impeller goes into and toss the one that's stuck? I mean all this fuss over something that can be replaced rather than re-used. It makes no sense?
    V Sport Wagon likes this.
  2. PriusMettaFitx
    PriusMettaFitx Junior Member
    17
    Nor Cal
    Good point. I may do that. I’ve tried torch heat, wd40, and sandpaper. It seems to be stuck on the inner diameter where the metal prong it. I can get it out about an 1/8 inch and can also slide a thin credit card on the outer diameter between the impeller and the plastic on the pump housing but no budge
  3. PriusMettaFitx
    17
    Nor Cal
    Here’s where I am at.
    just trying to save a couple hundred bucks and use my new impeller
  4. PriusCamper
    13,416
    5,416
    That's enough room for an air compressor to blast it out...
  5. PriusMettaFitx
    17
    Nor Cal
    Yeah and I tried that too. No budge. It seized on inner diameter one I get it out about 1/8 of inch
  6. PriusCamper
    13,416
    5,416
    How about a pen knife? Preferably one that's extra long and extra narrow...
    PriusMettaFitx likes this.
  7. PriusMettaFitx
    17
    Nor Cal
    Got it! The 2 ton puller loaner tool did the trick!!
    ASRDogman likes this.
  8. PriusMettaFitx
    17
    Nor Cal
    Pic
    xliderider likes this.
  9. PriusCamper
    13,416
    5,416
    Lol... I have two of those tools... Didn't think of suggesting it because it seemed like more than you'd need.
  10. Brian1954
    Brian1954 Senior Member
    2,664
    1,065
    South Central PA, USA
    Can you please post a few pictures of the white plastic on the end of the impeller that you removed?
  11. PriusMettaFitx
    17
    Nor Cal
    The outside white plastic was fine. It was the inner diameter (against the shaft) that the plastic pealed off and caused it to be stuck
  12. PriusMettaFitx
    17
    Nor Cal
  13. PriusMettaFitx
    17
    Nor Cal
  14. Brian1954
    2,664
    1,065
    Very interesting. This is the first time that I heard that the problem was on the inside diameter. Thank you.
  15. PriusMettaFitx
    17
    Nor Cal
    Yeah it was about a centimeter wide ring and that’s what was causing it no to be able to slide off
  16. ASRDogman
    ASRDogman Senior Member
    8,050
    4,082
    Did the shaft get damaged? Were you able to clean it up to make it smooth?
  17. PriusMettaFitx
    17
    Nor Cal
    It looks good and spins great with new impeller but I’m gonna clean it a bit
  18. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    You can buy those water pump rebuild kits on eBay as well, it's just the magnet and the impeller piece swap out. Or spend the whopping $275 for a new OEM pump and be done with it. This is not something you want to risk..
  19. PriusMettaFitx
    17
    Nor Cal
    yup, I got a new impeller for $30 and am using my old pump
    ASRDogman and V Sport Wagon like this.
  20. ASRDogman
    8,050
    4,082
    I have 47,000 miles on my impeller....
    Tande likes this.
  21. Rick Eiben
    Rick Eiben New Member
    Alaska
    Three Touring
    I know exactly what you’re going through and I have the same problem. I’m going to try to drill two holes on either side down into the metal and put an easy out in each one that way it’ll be a balance pull and it should come out. The magnets are just holding it in there and there’s really no way to pride out because the impellers gone.
  22. Rick Eiben
    Alaska
    Three Touring
    I have the same problem. I read through all of these responses and I’m not sure anybody really understands. Here’s what I did. Drill a small hole close to the center of what’s left, using thread cutting oil and go slowly. Get yourself a small easy out, and gently put it in there, tapping it with a hammer if you need to, and twisting until it’s firmly in. Use a small flat bladed screwdriver wedged in the side if you need to keep it from spinning while you’re working on it. Then spray a little WD-40 down in the middle, laid on its side and gently twist and move it around until it comes out. Mine was very difficult because it melted a piece of plastic to the shaft from the impeller. That’s what was keeping it stuck in there.
