Water pump replacement 2016
Discussion in 'Gen 4 Prius Main Forum' started by Jama707, Sep 21, 2022.
  1. Jama707
    Jama707 Junior Member
    SACRAMENTO, CA
    The water pump not coming out like in Gen 3. It seems very tight space now just a millimeter small. What has changed? Do we remove engine just to remove the water pump now?
  2. ChapmanF
    18,584
    amos likes this.
  3. Tideland Prius
    16,623
    Sorry is this for a Gen 3 or a Gen 4 car?
    alanclarkeau likes this.
  4. ChapmanF
    18,584
    I think the point of "not coming out like in Gen 3" was that, in Gen 3, it comes out, and in Gen 4, it ... doesn't.
    The repair manual straight-up says to pull the engine and transaxle in order to remove the water pump, in Gen 4.
    amos, alanclarkeau and Tideland Prius like this.
  5. Jama707
    SACRAMENTO, CA
    Yeah I was able to get it out by removing the engine mount bolts and moving the engine about 2-3 inches down with floor jack holding it and it came out.
    thomassster, amos and Jburner like this.
  6. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    Are the engine mount bolts located by the passenger wheel well?
  7. Jama707
    SACRAMENTO, CA
    Yes. I think there are two bolts. You might not need to remove the three bolts holding the base of the mount. But I did remove them and it might not be necessary to remove them.
