Water Pump with Metal Impeller?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DMK512, Aug 10, 2023.
  1. DMK512
    DMK512 Junior Member
    Austin, TX
    I bought a used 2010 late last year and I'm going through replacing all the fluids plus other maintenance tasks so I have a baseline and I'm not assuming anything was done and having it bite me down the road.
    The car had 166K at purchase and 174K now. I've changed the oil twice, It does use a quart every 12-1500 miles. I've run the BG oil flush and added the MOA at the last oil change. Separate issue.
    I just drained and filled the trans fluid. It took 4 qts. to refill, and that seemed low. I will check it again shortly.
    Now on to the main issue. Next on the schedule is engine coolant. I did the voltmeter test and it came in at .2 V, with my understanding that .4V is the warning threshold. I plan to change the water pump and thermostat at the same time.
    Now comes the question. Having an aversion to plastic in the cooling system (Bad experiences with BMWs and also prius stories), Is there a replacement water pump available that uses a metal impeller instead of plastic?
  2. Tombukt2
    Tombukt2 Senior Member
    13,857
    2,516
    Durham NC
    Not that I know of I've looked at a bunch of different ones and they all seem to be made by one or two factories in the no name ones literally have the Asian name ground right off the front aluminum part of the cover It was never stamped there to begin with or something along those lines The plastic that messes up on the impeller is not the impeller per se It's the wrapping of the windings or whatever you call that stuff that's in a mag drive impeller because there's no physical shaft running from the motor to the wedding like a pool pump has a shaft that runs through it these are more like a washing machine drain pump or a mag drive pool pond pump. The plastic wrapping the winding or the metal that is in the center of the impeller if you will that stuff wears out gets excessively heated swells and then the impeller won't spin and it's bore You can take it out the impeller and clean it up literally take the plastic off of it put it back in and it'll work pretty much perfectly. I don't know how long that metal can stay exposed until it rusts and is gone completely. You can buy impellers apparently on Amazon for $24 that's usually what goes bad in these pumps Good luck with your car man.
    DMK512 likes this.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I've never seen a metal impeller replacement advertised for our cars.
    Interesting. What's the voltmeter test?
    moto g power ?
    jzchen likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    I thinks it's 3.8 qts for the transmission. Was the car level when you drained and filled it.
    You fill until it seeps out of the fill hose.
    Where did you get that there was voltage in the coolant? HOW did you measure that??????
    WHY would you change the coolant pump?
    Doubtful you'll find a metal impeller. The impeller will likely only brake if you drop it, like I did.
    It's the white plastic surrounding the magnets that will swell up.
    I still have the original thermostat at just shy of 310,000 miles.
  5. DMK512
    Austin, TX
    My understanding of the theory behind the voltmeter test for coolant is that as coolant wears out, and becomes acidic, and acts like a battery electrolyte between the cast iron of the block and the aluminum cylinder head. It's referred to as a galvanic response, and creates a small electrical current flow between the two metals. The result being erosion of the metal. This may contribute to eventual head gasket failures or other component failures.
    The test is simply open the radiator cap, stick the positive probe of a multimeter set to 20V scale or lower into the coolant, and touch the negative probe to a ground point if you measure .4V or more the coolant should be changed.
    Here's some more detailed explanation with links to futher reading:
    https://bobistheoilguy.com/forums/threads/multimeter-for-testing-engine-coolant.271663/
    What is Moto G? I used BG Products brand oil flush and oil additive on my last oil change.
  6. DMK512
    Austin, TX
    I pumped in just under 4 qts of WS fluid when it started leaking out of the fill hole, so 3.8 seems about right. The car was in the air on a rack, probably pretty close to level.
    See my reply to ASRDogman regarding the voltage test.
    I expect that if the coolant is changed within it's life limit parts last longer. If the change is neglected, coolant gets acidic and parts start degrading. To me it's cheap insurance, like changing out the water pump when you do the timing belt (on different cars), especially when the timing belt needs to be remove to get to the water pump. I do see now that there is replacement impeller (with magnet) available for the water pump at around $30 which may be an option.
  7. Mendel Leisk
    42,343
    If just the front of the car was raised, and considering the transaxle drain bolt is towards the rear, I think you’d end up filling less, not more. 3.8 qts sounds about right; think I managed something around 3.6 liters, which are slightly bigger.
    DMK512 likes this.
  8. Mendel Leisk
    42,343
    BTW, not noted in repair manual, but I did find in a Toyota document somewhere: only use Toyota ATF WS fluid from freshly opened bottles. In other words, recycle any leftovers. I’d gather it attracts moisture over time?
    More info in one of my signature links (on a phone turn it landscape to see signature).
    DMK512 likes this.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    I would do 3-5 years or 50k miles or less coolant changes. 100k or 10 years initially is too long a period.
    I would be most concern about degradation of the rubber (synthetic polymer) in the head gasket leading to a very expensive repair. Coolant is cheap compared to a head gasket replacement. Using an airlift system or equivalent, a coolant change takes about 30 minutes without the need to do multiple starts and stops and getting the car into the service mode.
    V Sport Wagon and DMK512 like this.
  10. DMK512
    Austin, TX
    I do have a vacuum cooling system filler and plan to use it. Any tips on making certain as much coolant as possible drains out in the beginning?
  11. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    No need to get every drop out. Just drain the radiator and get out as much as you can. The little that you can't get out by not opening the block drain is totally diluted by the new coolant. The block drain may be corroded and either break of or not reseal. It's not worth the risk to bother with it.
  12. Tombukt2
    13,857
    2,516
    Durham NC
    Our engines are all aluminum are they not?
    CR94 likes this.
  13. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    As for the replacement water pump, I get a brand new Asin made OEM quality Toyota one. Any aluminum impeller one might not be better. A heavier aluminum impeller has a greater moment of inertia and is harder to start or stop, so it may not function any better and would likely be worse.
    You really want to monitor water pump efficiency which is directly related to coolant temperature. The best way to monitor this is a Scangauge 2. I use mine to also monitor the 12 volt battery voltage, the HV battery temperature and the inverter coolant temperature. The Scangauge does this continuously and warns you of any impending issues.
    Here's how mine looks at the spot above the steering column cover.
    DMK512 likes this.
  14. ASRDogman
    8,063
    4,086
    If you really want to drain all the coolant, don't forget to disconnect the hoses off the converter
    under the car.....
    And if you fill VERY SLOWLY, non need for vacuum....
  15. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    Great minds think alike.
    I have thought of this too but there are none.
    Would be perfect to replace the plastic one.
    DMK512 likes this.
  16. DMK512
    Austin, TX
    You are correct. I need to investigate further how the electrolysis process affects all aluminum engines.
  17. DMK512
    Austin, TX
    By converter, do you mean the D/C-A/C inverter? The engine and inverter coolant systems are completely separate. The inverter cooling system has it's own radiator and electric circulating pump.
  18. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The reason for the shorter interval after the initial coolant change is that you leave some old coolant in the heater loop.
  19. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    To be really safe, I do the 3 year coolant change interval.
  20. ASRDogman
    8,063
    4,086
    Yes, I know there are two different systems...
    I forget the name of it, but as I said, under the car, where the coolant hose
    goes to the "dirverter(?)" to heat up the coolant faster.
    It's under the car, before the catalitic converter...
    When scum bags steal the coverter, they sometimes cut those coolant lines....
