Water Valve/coolant control valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vegliare, Dec 5, 2018.
  1. vegliare
    vegliare Junior Member
    Greenacres
    Hey all,
    Moms 2008 has a P1121 code that reads as coolant control valve. Shop wants $400 parts/labor. I figured I would just do it myself then replace other needs at the same time.
    My question is at her mileage of about 110k, should I look at also replacing things like coolant temp sender, water pump, etc.
    Thanks for your input.
  2. JC91006
    16,936
    8,647
    Some states that have emissions warranty for 15 years/150k miles, so make sure you are not in those covered states before you start messing with it. It could be free
    SFO likes this.
  3. Patrick Wong
    18,210
    6,522
    I would suggest you look at the engine coolant pump and replace it if there is any sign of coolant weeping at the bearing. Maybe replace the engine thermostat. Definitely replace the serpentine belt.
    I have not seen any reports of a failed coolant temperature sensor so that would be low on my list of items to worry about.
    Are you aware of the need to purge air out of the coolant heat recovery system loop? If you are not aware of that requirement, please see my posts #22 and #42 in the following thread plus the surrounding discussion.
    Changing engine coolant | Page 2 | PriusChat
    The two main thoughts to keep in mind are: 1) keep track of the amount of drained coolant as you know you are not done until you've added at least that amount back into the system and 2) you need to run the CHRS pump either by using Toyota Techstream via software control, or by manually bypassing the CHS relay as my post explains.
    SFO likes this.
  4. vegliare
    Greenacres
    Thanks all. And sadly Florida is a bad example in regard to emission regulations, as in they basically don’t exist.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Hey Pat is there a write up on replacing that valve mine is starting to get cranky thanks.
    Ray
  6. Patrick Wong
    18,210
    6,522
    Hi Ray,
    I have not had to change that valve but I believe others have written about that.
    edthefox5 likes this.
