Waterless Coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jbrad4, Jan 31, 2012.
  1. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    I am thinking about putting waterless coolant in my new Plug-In Prius.
    Questions:
    Does anyone have waterless coolant in their Prius now?
    If so, how do you insure that you get all the water based coolant out?
    How well does your Prius run on the waterless coolant?
    Do you get increased fuel economy as claimed?
    Thanks,
    Jay Leno Talks about Waterless Coolant
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Supposedly, the MPG benefit from such would be that the engine cooling fan need not come on as much, because operating temperature can be higher. This means that electrical load is lower. However, in a PiP, the engine is going to run cool anyway -- too cool in the winter already.
    I can see the benefit from using this in a very old car with a non-pressurized system. The case for a PiP seems much less compelling. Good luck getting all the coolant out of the engine+heater core.
  3. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Waterless coolant started with the Volkswagen Beetle right?
    bisco and m.wynn like this.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The 1902 Franklin had the VW beat by a few years. I doubt that the Franklin was the first.:cool:
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    And this wouldn't void the warranty?
  6. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Ha, just being a wise nice person, VW being air cooled
  7. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Sorry to revive an old thread but I just wondered did you ever try the waterless coolant? I can see several advantages but a little worried about the electric water pump.
  8. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Waterless coolants? What do you mean by that?
    Does such a xoola t have the same properties inherent in a Toyota coolant?
  9. Mendel Leisk
    42,380
    Here's the Jay Leno video:
  10. Prodigyplace
    12,720
    11,852
    Central Virginia
    What advantages for a Prius?
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Well, as long as its the Evans guys, have got no problems with that.
    They doing a great job with their engine oil flush stuff, and coolant flush products too. Great company.
    I think the colourless, is just colourless, with it's additives intact.
  12. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    First advantage is no corrosion inside cooling system.
    Second advantage is that its very high boiling point means better cooling, because vapor cannot cool.
    Third advantage is that very high boiling point means that the cooling system doesn’t get put under high pressure, so hoses and all components of the cooling system should last longer.
    As I understand, Prius has a closed system which keeps coolant under pressure in order to prevent boiling. But even so, my understanding (and I could be wrong) is that the higher boiling point should keep the pressure lower than a coolant with water.
  13. Prodigyplace
    12,720
    11,852
    Central Virginia
    Do we know it is safe for the components of the Prius cooling system? I worked for a company who decided to use a different coolant in their TV transmitter. The coolant corroded the tubes and the silver plated racks that held them.
  14. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You're right. I think I'd prefer a colourless coolant, if offered, than ordinary water.
  15. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think to answer your ??, would require some kinda analysis on the components after some time. I hope anyone that has used the coolants would afford to share such data, if eventually it was done.
  16. padroo
    padroo Senior Member
    2,763
    2,253
    If your car is under warranty I wouldn't try it, might void your warranty.
    I have looked into it and should use it on some of my older cars.
    Speaking of cooling systems I wonder how Gen 4 Prius will be to get the air out of the system?
    My Gen 2 was rough for both the cooling and hybrid systems.
    Prodigyplace likes this.
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    My point is that the testing should be done before somebody tries it and destroys their car.
  18. Mendel Leisk
    42,380
    I wouldn't try it, but it sounds very interesting. More so if it was used from the get go, put in by Toyota at the factory.
    As it is, it'll be 10 years before our coolant is due, and by that time, I'd be reluctant to do anything but replace with same.
  19. Rebound
    3,996
    2,645
    Portland, OR
    Maybe the manufacturer can tell you. This product has been in widespread use for at least fifteen years, and used in a lot of vehicles, so I seriously doubt there’s some magic pixie dust material inside a Prius cooling system which corrodes when exposed to non-corrosive coolant.
    People use this on very expensive vehicles — Jay Leno uses it in his Duisenberg and in a Bugatti, and more... so it appears to be well time-tested. It just doesn’t seem likely that a Prius has something destructible inside.
    That said... does it make sense? As far as I can tell, Prius cooling systems don’t corrode nor do they have failure points. And these aren’t vehicles which remain parked for long periods of time, like antique cars. Prius engines don’t get especially hot and they aren’t known to overheat. Given all that, I don’t know if this coolant has a benefit in a Prius, because Prius owners haven’t identified a problem which needs solving.
  20. Prodigyplace
    12,720
    11,852
    Central Virginia
    I just meant "Buyer Beware".
    Copper heat sinks and silver plating do not corrode either, especially if 3M DowTherm coolant is used. The local chemical company said their blend was equivalent -- It wasn't :cry:
