watt-hour metering
Discussion in 'Prime Plug-in Charging' started by Old Bear, Oct 19, 2017.
  1. fuzzy1
    10,713
    To do it right, you are not missing anything. It takes two current sensors, one on each hot side of the split-phase system.
    But wiring all the 'hots' through a single sensor core, as shown in McRascal's diagram (one phase straight, opposite phase reversed) should work as a reasonable 'kinda-sorta' approximation in most cases. It would be just fine if the supply was perfectly clean and balanced, but that isn't the real world. Ordinary impedance and mismatch issues will make it susceptible to interference from other unmonitored loads on the same local transformer, but may be close enough for coarse approximations and monitoring.
    On three phase systems, this approximation completely falls apart.
  2. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I am installing a 20A Z-Wave outlet which can monitor power and energy and send that info to my SmartThings which I can view in my iPhone. Just another way to monitor power.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Which make/model are you using?
  4. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Enerwave ZW20RM Wireless Z-wave In-Wall Smart Meter Energy Monitor TR Duplex Receptacle,120VAC, 20Amp
    jb in NE likes this.
