Way to turn OFF the default so the car does not go into EV mode at start??
Discussion in 'Prime Main Forum (2017-2022)' started by bear15, Jul 1, 2017.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Is there a way to turn OFF the default so the car does not go into EV mode every time you re-start the car?
    51,104
    no, but all you have to do is press the hv button. or if you're out of plug charge, it starts in hv.
    HPrimeAdvanced likes this.
  3. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Many thanks!
  4. stevepea
    stevepea Senior Member
    535
    581
    Not clear what you mean. You can always push the HV button to put it in HV mode, but remember, even in HV mode, the car will be in "electric mode" for lower speeds, like when first starting the car (ie, backing up out of the garage, etc).
  5. bisco
    51,104
    it will start the engine and warm it up though, yes?
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    944
    Sparks, NV
    I read this somewhere and makes sense - the Prime defaults to EV because that allows Toyota to meet the requirements that the Prime is an EV vehicle, thus qualifying for the federal tax credit.
  7. schja01
    schja01 Senior Member
    1,819
    1,207
    Chicagoland
    2024 Prius
    Limited AWD-e
    Just never plug it in. But then what’s the point of having a Prime?
  8. Prodigyplace
    12,398
    11,678
    Central Virginia
    Buy a Prius Liftback? :D:LOL::ROFLMAO:
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Press and hold the A/C button on your remote key fob. It will lock the doors and start the HVAC system to either heat or cool to the set point you left the last time you were in the car. It'll run the heat pump or the engine as needed.
  10. Trollbait
    12,335
    Does the car only default to EV only, or will it start in EV Auto if that was the mode it was in when shut down?
  11. bisco
    51,104
    Ev only
  12. bisco
    51,104
    This thread is closing in on two years old people :)
    Prodigyplace likes this.
