Ways to lower 12v power draw when car is sitting?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tnx, Feb 14, 2018.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Dont bother measuring it at the battery itself measure it at the jump points. At the battery measurement is meaningless really I want to know what voltage looks like at the fuse box because thats where the car draws it from after going through it main fuse assy and a long #2 gauge cable and then some more fuses. Thats the true working voltage of the battery.
    Best place you can measure is it at the jump points. With car off measure at the jump points and write it down. Then with car OFF turn on the headlights and measure again. See what the voltage drop is. Write it down. Put the high beams on and measure that voltage.
    Based on what Im seeing here and its bad for the battery life and never maintenance charged a 12.3 resting at the battery it will probably drop quite a bit into 11.7 I bet with the high beams on.
    Post your test back here.
    Unloaded.
    Lights on.
    Hi beams on.
  2. Mendel Leisk
    41,497
    Pep Boys test shows CCA higher than spec., which is good, indicates a battery in good shape. I would get it on a smart charger during protracted idle times, multiple days. In your case it's a pain, but I think the best solution.
  3. Tnx
    Tnx Junior Member
    Claremont, CA
    I drove it around further and testing the battery an hr after long/short drives has gotten me consistent readings of 12.20-12.3 now. I will do the test that EdTheFox5 posted and post back.
  4. Mendel Leisk
    41,497
    Pretty low numbers.
  5. bisco
    51,983
    you're now testing it after driving, instead of after it has been off overnight?(n)
  6. Mendel Leisk
    41,497
    Overnight it's likely to drop even lower? Maybe it's time?
  7. bisco
    51,983
    exactly. still trying to figure out that pep boys printout though.(n)
  8. Mendel Leisk
    41,497
    Yeah that bothers me too: good CCA. Run it through another complete charging session, with the 200 foot extension cord, if that's what it takes.
  9. Mendel Leisk
    41,497
    Hmm, Deltran Junior is only 750 miillamps. Needs more, decent 3~4 amp smart charger is needed.
  10. Tnx
    Tnx Junior Member
    Claremont, CA
    @bisco, I tested it 1hr after driving because another user posted that "According to the manual: 12.6-12.8V: fully charged, 12.2-12.4 partly charged, 11.5-11.9: discharged. Measurment to be taken 20 minutes after powering off the car and consumers."
    I had let the car rest overnight and the morning test was also the same as 10~ hrs the day before, about 12.23. Didn't seem to drop at all so I was hoping that was a good sign. I'll charge it fully again and post back.
  11. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I wouldn't fret about those voltages. That is what I see as well. Mendel may have an optimistic voltmeter. ;) The voltage that you see at the boost point is -slightly- lower as it is at the OBDII port (what the Scangauge sees). Going by what some on this forum say, my Scangauge readout would have me changing my 12V battery every other week. ;)
  12. bisco
    51,983
    mine reads within a tenth of a volt tween the battery and boost point.
    Raytheeagle likes this.
  13. cipsaz187
    cipsaz187 Member
    148
    42
    Alright, I left my 2012 Prius on battery minder for 3 weeks. It measured 13.7V when I disconnected the cables.
  14. Mendel Leisk
    41,497
    In the pink, plus surface charge.
