WE CAN'T CHANGE YOUR OIL / you have the WORLD FLUID in there...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KD6HDX, Sep 29, 2007.
  1. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    This is my first time starting a topic:
    Yesterday, I took our 05 Prius to Longo Toyota here in So Cal. I wanted a transmission fluid drain and refill, and my coolant system to be drained, flushed and refilled with new coolant. 2 hours later, my car is ready and the price was a lot lower than I thought it should be. I looked at the paperwork and discovered they only performed the radiator coolant drain flush and fill job order. The reason given for not completing the transmission fluid change was stated as, "HAS WORLD FLUID, NOT ABLE TO CHANGE IT".
    I paid the lower price and then asked to speak to the service writer, who said, "they can't even check the oil or replace it, it has the world fluid". I said, but I like to do preventive maintenance and I already have 70K miles in 2 years of ownership and I want the fluid changed. He was polite and stuck to his story.
    This is the dealer where I bought the car from. I have the extended warranty, and I just want my Prius to last a long time. I mentioned all that to the service writer and he agreed with me, but said his technicians could not do the job. I said OK, and scratched my head while I drove home from the dealer. Let me say that I really like Longo Toyota, they are a first class operation and I trust there opinions. But I want to know from any of the hybrid trained technicians here on PC what they think of this.
    Can somebody tell me if I should accept this or demand a fluid change? Why did this dealer deny me the service and should I be OK with it?
    Riddle me this Batman.......
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You should demand the change and many of us recommend that it be done just about this time...I did mine at 60k miles.
  3. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    Thanks Evan,
    I will be calling their service department this week and inquiring further into why this cannot be done. Hopefully somebody there will be able to explain this to me and possibly convince me if it sounds right. I would much rather change it out and do the right thing. But the service writer almost made it sound like it was not recommended.
    Will report back later after I start calling today.......
  4. efusco
    19,891
    1,192
    Nixa, MO
    The next thing you'll face is probably that it's not 'required'/recommended until 100k miles. You'll just need to stick to your guns that you've done the research and several posted used analysis have confirmed that excessive wear and mineral collection even at 60k and you'd prefer use an abundance of caution to protect the ICE.
  5. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    Protect the ICE? I was hoping to protect the eCVT. All of my oil changes since 5K miles have been Mobil 1 synthetic. Hopefully the ICE is protected. How does the tranny fluid so to speak, protect the ICE?
    ....going to the phone....
  6. efusco
    19,891
    1,192
    Nixa, MO
    misspoke/typed....of course it's the transaxle/psd.
  7. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    Roger - copy,
    I just called, and they're real busy now, but I will call during the week when the chances are much better that I will be able to speak to a service manager, and not my service writer. My service writer was with another customer, and his voice mail was offered to me, but I declined and said that I would rather ask my questions to a service manager.
    So I'll try on Monday and post the results right here.
  8. Rest
    Rest Active Member
    1,210
    53
    CA
    Stealerships would never lie...would they?
    This is why I do all the service myself!
  9. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    ...hopefully they are a dealership, and not a Stealership. I may try it myself, but I would feel better having them do it. I do my own air oil and cabin filter changes myself.
    wish me luck.
  10. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    LOL. the biggest prius shop in the nation doesn't know how to drain and fill trans fluid.
    yep it's sealed in there nice and tight. no way to get it out. you're stuck with it forever. :rolleyes:
  11. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Maybe they don't bother to carry the correct fluid????
  12. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Gee, you usually have to talk a dealer out of gratuitously changing fluids.
  13. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(KD6HDX @ Sep 29 2007, 10:45 AM) [snapback]519091[/snapback]</div>
    If you still get the run-around, you might want to consider going to another dealer.
  14. patsparks
    10,664
    567
    Adelaide South Australia
    Go to spare parts and buy the oil then deliver it to the service manager with the car, somewhere here there must be an ilustration of where the drain and refill plugs are. Print a copy, hand that to him and tell him he needs to join PriusChat.com
  15. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    UPDATE:
    I just got a callback from one of the Service Managers at Longo. He mentioned that Toyota does not recommend that service until 120K miles or at 60K miles if you are towing a trailer. :blink: He also stated that they would do it if I wanted it done. Later this week I will have it done, probably next Thursday or Friday.
    While on the phone with him, I mentioned that I would like a discount of at least 15% because I had to go to them again and I live a considerable distance from them. When I went the first time for the coolant drain and fill, plus the tranny fluid change, I had a 15% coupon that they had sent me in the mail. He agreed to the discount and said that he would add this request to my account info. Maybe I will just ask for an oil change coupon instead?
    I made it clear to him that I was not calling to complain about the service writer, A couple of times I mentioned him by name and stated that he was polite, and also agreed with me that he would feel better having it done sooner than later. So I did not want to get the guy in trouble. My faith has been restored with Longo. During the conversation I mentioned that I had spoke with several people on-line about this, and that many hybrid technicians recommended the service sooner than later. Maybe this is why they will do it? Anyway, I will report back when the service is complete, and if there is any noticeable improvement in the vehicles overall operation / fuel efficiency / yada.
    Our Prius will never tow anything, except my brother in laws fat-nice person...... :lol:
  16. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(KD6HDX @ Oct 1 2007, 02:16 PM) [snapback]519931[/snapback]</div>
    Not mine
    It's fairly easy to change yourself. Just remember to take the FILL plug off first. Mine was on so tight from the factory, even with a proper 6-point socket, I just about couldn't get it off. Although I did manage to mumble humorous new combinations of very bad words
    Using an outboard lower-unit gear oil pump, it was easy to refill the case. With my 4 litre tin can of WS fluid, I had perhaps 250 ml left over.
    Don't let anybody talk you into a "flush." It's patently impossible on a +2004 Prius. There is a drain plug and a fill plug. If you really are worried about crap in the case, drive a week or so, and drain/refill again. The drain plug magnet will be a strong clue to if an accelerated drain/fill is called for
  17. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    I actually think that the 100K or 120K service interval should be fine. The Prius Transaxle does not have any clutches or bands that slip against each other like ordinary transmissions or CVT. It has a single fixed gear ratio and is more like a differential as far as service needs would be concerned. How often do people change their differntial fluid? I believe there is also a heavy chain in there too, but that is more like an extra heavy timing chain in the engine.
  18. MrK
    MrK New Member
    30
    <div class='quotetop'>QUOTE(jayman @ Oct 3 2007, 08:58 PM) [snapback]520964[/snapback]</div>
    Jayman, I was under my Prius, and I would question whether changing the CVT fluid is fairly easy. I couldn't even find the fill plug or drain plug! Where are they hidden? I've looked, but cannot find a link or thread on Priuschat that tells me.
    What size is the 6-point socket, as I wouldn't want to round off any corners. Is it really a socket, or is it an allen wrench? (I guess I'd know which it is if I could find the plugs.)
    Any direction you can provide would be most appreciated!
  19. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(MrK @ Oct 4 2007, 10:43 AM) [snapback]521189[/snapback]</div>
    http://techno-fandom.org/~hobbit/cars/maint50k/
  20. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(KD6HDX @ Oct 1 2007, 12:16 PM) [snapback]519931[/snapback]</div>
    So, they finally got the service book in that has the instructions? :blink:
