Weak A/C when it is hot
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Jun 24, 2019.
  1. bisco
    52,863
    there are twofers in front of the radiator, iirc.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,068
    954
    Southern California
    Took it back to the dealer and they worked on it, keeping it overnight. Two days later a digital temperature probe reads 44.2F in the driver's side center outlet for outside 91F (car's reading), 17% humidity (nearest weather station), A/C set on recirc, max cold, medium speed fan, doors closed and windows up, after running 5 minutes. At startup it fell quickly to 47F and then slowly the rest of the way. I checked the condensate under the car with a UV flashlight and it did not glow. Here are the notes on the service form:
    By shredder and shreder valve they mean Schrader, yes?
    Skibob likes this.
  3. pasadena_commut
    3,068
    954
    Southern California
    Today it was 81F so I turned on the AC and the outlet air wasn't even slightly cooled with T set to Max Cold. The last time the AC was on was in November and it worked then. So the September AC repair held for two months but not "permanently". Grumble. Back it goes for repairs on Monday. So far this has wasted a lot of my time but none of my money, since the dealer is still trying to fix it under the original sales warranty. I give them credit for honoring that warranty but this has convinced me to never, and I mean NEVER, take a car to them for AC repairs on my own dime. Here's hoping the third time will be the charm.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Well, that stinks. I once had to take an Intrepid back about about a half dozen times for AC repair. I had it in a nearby independent shop. I was working a temporary job in California and coming home every other weekend. Four trips in a row, I would fly home and the AC would quit on my first or second drive. Take it back, drop it off, and go back to CA. It was like Groundhog Day. Finally, I took it to the Dodge dealer and made the independent shop pay for it. (The indie shop balked, but I suggested that neither of us wanted the complications of third party involvement. They took the hint.) Next trip home, it quit again. Dodge finally got it right on the second try.
  5. pasadena_commut
    3,068
    954
    Southern California
    They replaced 88501-47041 (evaporator sub-assy) and 88515-0E070 (valve, expansion, no) and refilled it with R134 A/M. Seems to be working now but time will tell. Also it needs to be tested on a hot day, not so easy to test the A/C when it is only 65F. Looking at the diagram here:
    HEATING & AIR CONDITIONING - COOLER UNIT. Toyota Prius | John Elways Crown Toyota, Ontario CA
    I sure hope that the valve comes with the two O-rings marked with 88710H, or that they replaced them and didn't note it, because if they reused the 14 year old ones it will probably leak again.
  6. lech auto air conditionin
    830
    606
    261
    san francisco
    I guess I will have to make a video just for Priuschat just on (HOW TO TEST YOUR A/C WITH OUT GAUGES).
    If you have some refrigerant in your system 90g., 150g., 250g. that will be more then enough to run the compressor. Even if you only have 1 drop of liquid refrigerant in your refrigerant system that is WAY MORE!!! then enough to produce the pressure to close the low pressure switch and engage the compressor at first.
    Lets say we are vary low at 250g. the morning is a nice cool 57F you turn on your A/C but you will need some sort of temperature measuring device, long probe to fit down the vents preferably.
    lets say you do not have experience with experience compressors, with all the other noises you can not tell if it is running. (no clutch LOL)
    1: With the A/C on with 250g. and 57F anbient temp. you may have 47F even 43f out your dash. Later on in the day say around 75F 78F you may have 70f to 72F almost so little you are not sure its working. But in the morning it droped 10F to 14F something happened for sure.
    2: If you took you hand in that morning you would feel the suction line (big pipe) leaving the evaporator feels about 37F if but later that day if you touched the same pipe in the same place it would feel 65F for example maybe a little more or less. too close to tell using your hand. (except with lots of experience " temperature calibrated fingers").
    3: Now with the a/c running if it is. ( only a experienced person "WARING MAY LOSE FINGERS"!!) FAN MAY START AT ANY TIME.
    You reach down and touch the suction line entering the compressor it mat be 70+F may have picked up some hot warn engine heat slightly warming the suction line. Now reach over and touch the discharge line leaving the compressor. If it has been running for some time ( BE CAREFUL IT MAY BE BURNING HOT TO UNCOMFORTABLE HOT!). Then this means the compressor is running.
    Now the reason the compressor is so hot is because the compressor is starving for oil and cool refrigerant return. A over charged a/c with refrigerant can give you a burning hot discharge line too???
    OMG for the people who know about using a P/T (pressure temperature chart) how can I get the same hot high temperature with both low pressure and high pressure???. ( this is for the guys who re-charge by pressure or temp). or sight glass LOL.
    Also there is a point were the refrigerant level is low just at the right point were the pressure is much higher then then when it is 100% correctly filled. As if was over filled, restriction, fan not working or too slow, over heating radiator, hot water flowing in the heater core and hot air mixing with cold air putting a load on the evaporator at the same time. All these that can give the sane test data symptoms. That's just the top of the list not every thing.
    Not to mention all the shops and DIY who DO NOT own a refrigerant analyzer and recover contaminated refrigerant. Mix it with all their recovered gas then put it your car like a STD. Then there is the guy who uses shop air to pressurize the a/c system to test for leaks. You may as well pour water in the a/c compressor, same thing. The shops that do not change the filter drier on the recycle
    machine a lot of moisture contamination. Shop that use old RRR ( refrigerant recycle machine) that only has a weight scale accuracy of +- 60g to 90g ( 2oz to 3oz) when they were brand new lets not even talk about after 5 ot 10 years. On a Prius with a charge of 420g add 3 oz and see what happens or remove 3oz and you get what happen happen to this car of ( PASADENA_COMMUT)
    Just a little leak just a little low because a leaking EVAP. We hope that all.
    OH YEA Just 90g (3oz) over charged or 3oz low refrigerant charge and the Prius GPM takes a nose dive. (tell me why ???...
  7. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Precision. Get exactly the right amount of refrigerant in there and the compressor can stay in its comfort zone.
    Get it wrong and the pump is either fighting too hard vs. overpressure or it is running much longer to build up to normal pressure. Either way wastes a lot of power, and burning more gas is the only way the system can make up that loss.
  8. Mendel Leisk
    42,354
    It's good to run AC regularly, say at least weekly for 5~10 minutes. Using the heat/defog vent mode may also run AC, even if the AC button is not lit. Not using it for protracted time, the seals may dry out from lack of the internal oil circulating.
  9. lech auto air conditionin
    830
    606
    261
    san francisco
    Bingo you just won the $64,000 question.
    You would be amazed at how many mechanical shops I go into and they’re trying to figure out why the Prius is getting bad gas mileage and the engine keeps idling constantly often on when the air conditioning is on.
    Often many spark plugs get change ignition coils get changed anything to do with the engine or airflow or gas flow components taking wild guesses at changing parts to cure the problem.
    When all it was was 3 ounces of refrigerant in either direction.
    See what happens with the guys with the little cans to fill by pressure or temperature they believe they’re doing their customer a honest service.
    Yes air conditioning on a Prius can greatly affect your gas mileage” When it’s in properly charged!”. But when properly charged it just coast and idols along with no effort not drawing a lot of amperage from the HV battery.
  10. lech auto air conditionin
    830
    606
    261
    san francisco
    Actually that was in is true for the old-style mechanical compressors that have a external shaft seal connected to a external clutch.
    Like the old York and company and general motors or Frigidaire axial six compressors are the most famous for having the front shaft seal that is actually oil pressure Feed to keep it lubricated.
    But now we’re talking about completely sealed compressors with no external protrusions relying on a lip style seal.
    The seals at hose fittings we do not have to worry about when they decide to fail they’re going to fail not due to use or lack of use.
    dolj, valde3 and Mendel Leisk like this.
  11. pasadena_commut
    3,068
    954
    Southern California
    So, two and a half years after the evaporator was replaced, is the A/C still good?
    Well, it does blow cold, but maybe not quite as cold.
    Today with 95F outside (according to the car), 47% humidity (nearest weather station), max cold, recirc, max fan, windows up, in the sun the driver's side center vent quickly came to 55 F and then dropped slowly to 50.5 F over about 3 minutes. Change to fresh air, leaving everything else the same, and it very rapidly rose to 55.0 F out of that vent and then wandered around near that (.2F or so variation).
    So, let delta be outside temp minus vent temp we have now:
    delta recirc = 44.5 F
    delta fresh = 40.0 F
    Previous measurement from may 2019, right after an A/C recharge (see post a few up), had delta in recirc mode of 46.8 F. The humidity was much lower that day though, as was the temperature. Same electronic instant read meat thermometer was used.car
    There was condensation coming out under the car, and the drain tube was checked and appeared to be clear.
    So, is this still in the normal working range?
    I can think of four reasons why the delta was not the same in recirc mode, and these are in estimated order of likelihood:
    1. higher temp and humidity air has more heat to remove than previous test, so A/C slightly less efficient.
    2. slight refrigerant leak (parts of the original equipment remain, along with the very old O rings).
    3. dirty condenser (see below).
    4. dirty evaporator. (It is very dusty around here, it blows off the desert much of the year.)
    Can't do anything about (1).
    Hopefully not (2).
    I'm not sure how to clean the condenser coils, other than hosing down the front of the car. Is there a better method?
    Toyota sells a couple of cans for cleaning the evaporator. Worth the effort?
    ydpplqbd likes this.
