WeatherTech for 2014 PIP Trunk Area
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PhilBlank, Jul 9, 2015.
  1. PhilBlank
    PhilBlank Junior Member
    86
    2014 Prius Plug-in
    Does anyone know if the WeatherTech for a standard prius will fit the PIP?
    I don't need access to the storage compartment - just need to protect the trunk area from a potential spill.
    Thanks,
    Phil
  2. Okinawa
    Okinawa Senior Member
    1,333
    317
    You can google weathertech and get their toll free number and call them and they can probably help you.
  3. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    It will not. The shape of the interior on the passenger side is different on the PiP. I bought a custom fiberglass sub box, made for the passenger side cubby, and it wasn't even close to fitting. It's because of the charge port being located on that side.
    Redpoint5 likes this.
  4. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    I tried a Toyota OEM trunk mat from a base Prius into a PiP and it does not clear the hump for the charger. I'm assuming the Weathertech brand mat will be the same unless you trim it, and Weathertech does not offer one specifically for the PiP.
    So my answer is 95% "NO" unless you trim the Weathertech. You could contact Weathertech directly and ask their opinion.
    I ended up just getting the Toyota OEM trunk mat specifically made for the PiP: My new PiP - helpful comments appreciated | PriusChat
