WeberAuto: 2024 Prius Prime PHEV Low-Voltage Charging System Testing
Discussion in 'Gen 5 Prius Technical Discussion' started by KMO, Jan 7, 2025.
  1. Prodigyplace
    12,712
    11,848
    Central Virginia
    You also cannot conclude that the professor was wrong at the beginning of the video then. People here have been basking him and his expertise.
  2. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Is anyone saying he was wrong?
    (Maybe Gokhan is, but I've got him blocked)
    He was certainly surprised to see the main DC-DC converter working, but I don't think he ever said it was never used, so I can't yet see anything he said that was technically wrong (on evidence so far). I still suspect that if he'd kept instrumenting long enough that the 12V was charged (and he'd shut down everything else in the car) it would have shut off.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    This is from the Gen 4 NCF. They show a sub DC–DC converter inside the charger in this figure, but then they also say that it is inside the inverter assembly. Go figure. All I can say is that the voltage never goes over about 13.0 V in Gen 4 during traction-battery charger. In the video for Gen 5, there is clearly no 14.1 V output on the charger.
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    Yeah. thanks for the idea. Much less clutter now after blocking them.
    RandyPete likes this.
  5. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Couple more nuggets comparing with G4 docs.
    Its NCF has the same "Using the sub DC-DC converter built into the electric vehicle charger assembly, the auxiliary battery is charged with the minimum necessary power to reduce power consumption.", consistent with the G5 text being an erroneous carry-over.
    In the component functions it has this extra text missing from G5: "Electric Vehicle Charger Assembly: When plug-in charging, supplies voltage to the auxiliary battery via the sub DC-DC converter."
    And it has the same text about the battery heater, showing that G4 was already partially relying on the main converter.
    Fuses and wiring in G4 are
    AMD -> DC/DC 130A from main inverter with converter
    AMD2 -> AMD2 30A from the charger
    And the diagram of the G4 charger does show the sub DC-DC converter and connection to the auxiliary battery.
    That is not present in the G5 diagram (which I would post if my 1 hour TechDoc subscription hadn't just expired).
    So I think the evidence does point towards the G5 charger sub DC-DC having been removed altogether. Leaving just the erroneous holdover text in the NCF, and the charger connection and fuse with misleading legacy "this used to be a power output" names.
    (Looks like one is still present in the solar charger though.)
    RandyPete and Prodigyplace like this.
  6. Gokhan
    6,714
    2,661
    Paramount CA
    Here is the Gen 4 video. There seems to be indeed a ~ 13.0–14.0 V DC output from the charger (a sub DC–DC converter inside the charger) in Gen 4. However, in my observations, the 12-V battery stays at a float voltage of about 13.0 V during traction-battery charging in Gen 4—enough to keep the system running but not enough to charge the 12-V battery. Therefore, the current capability of this output is very low.
    So, the elimination of this sub DC–DC converter in Gen 5 is a most welcome thing, as it does more harm than good in Gen 4 by not charging the 12-V battery during traction-battery charging.
  7. Gokhan
    6,714
    2,661
    Paramount CA
    At the end, the lack or existence of a small (sub) DC–DC converter in the charger is a moot issue. Toyota is not known to make the best engineering decisions when it comes to electrical systems one way or the other.
    The end result is that:
    • Gen 4 keeps the 12-V battery at a float voltage of about 13.0 V during traction-battery charging but does not charge it.
    • Gen 5 charges the 12-V battery at 14.1 V during traction-battery charging through the (main) DC–DC converter.
    Other than that, the behavior of the 12-V-battery-management system (12-V BMS) in Gen 4 and Gen 5 seems to be identical.
  8. Gokhan
    6,714
    2,661
    Paramount CA
    While these videos are fun to watch as you can see the guts of the system, they have little value in helping understand how the 12-V-battery-management system (12-V-BMS) works.
    Get a BM2 Bluetooth battery monitor as some of us have, and you will have a much better understanding of how the 12-V-BMS works. You will be surprised to find out when the BMS charges the battery and when it doesn't. Last but not least, you can connect a battery maintainer before you end up with sulfation if you see that the battery SOC has gone too low.
  9. Gokhan
    6,714
    2,661
    Paramount CA
    If you ever get a battery monitor or something as simple as a cigarette-lighter voltmeter, which tracks the battery voltage closely, what you will find out is that you are driving the Gen 4 or Gen 5 does not mean that the battery is charging. The voltage will stay at a low float voltage of 12.89 V for most of the time unless the SOC has fallen below 75%. At other times, it will briefly charge at 14.1 V to make up for some of the parasitic drain.
    It is good that the Gen 5 PHEV now charges the 12-V battery during traction-battery charging, which doesn’t happen in Gen 4, which is apparently because in Gen 4, only a low-current “sub” DC–DC converter turns on during traction-battery charging. Also, reportedly, both Gen 4 and Gen 5 charge aggressively when it is very cold, which I cannot see in the warmer Southern California. However, these will still not change the fact that the 12-V battery is not charged for most of the time when you are driving the Gen 4 or Gen 5.
    So, don’t expect your 12-V-battery SOC to hover close to 100% as in your grandfather’s car. The Gen 4 and Gen 5 BMS does not do that. You will be lucky if it does not fall below 75%. Occasional use of a battery maintainer such as Noco Genius to bring the SOC to 100% to reduce sulfation is a good idea.
  10. peternumber2
    peternumber2 Member
    134
    36
    Rome
    2023 Prius Prime
    If this can help: when I park my car in the box, and I want to plug it, I need to lock it, so that the mirrors fold and there is room to move around: then i need to unlock it in order for the plug door to unlock. So what happens is that i lock -> reach for the plug -> unlock -> plug -> lock again. So I have the mirrors folding twice, first with the car unplugged and then with the car plugged and charging. The noise of the mirror motor is quite different in the two cases, suggesting a different input voltage.
    RandyPete and Gokhan like this.
  11. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    I had a similar annoyance, but it can be solved by configuring the car to fold the mirrors when turned off rather than when locked. It's one of the dealer/scantool settings.
    vvillovv likes this.
  12. peternumber2
    peternumber2 Member
    134
    36
    Rome
    2023 Prius Prime
    sorry my bad english may have made my message misleading: I'm not annoyed by such fold/unfold behavior: I described my experience since it seems to support the idea that the whole 12V systems (which feeds the mirrors motors) is stepped upa bit while charging from AC.
    Prodigyplace, Gokhan and RandyPete like this.
  13. Gokhan
    6,714
    2,661
    Paramount CA
    It was very clear to me what you said. ;)
  14. Prodigyplace
    12,712
    11,848
    Central Virginia
    No worries.
    Your English is MUCH better than my (non-existent) Italian. ;)
  15. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    2 months late or later finding Dr John D Weber @ weber state university video.
    I hope to be able to re evaluate my presumptions I'd gotten from reports from Gen 5 owners and the data we've been privy to as Gen 4 owners.
    Got the video playing in another window, for the second time as I post this..
    Thanks @KMO
  16. vvillovv
    4,337
    1,518
    NY
    At the 8 minute mark is where the video mentions the 12 Volt battery's, dc to dc converters sub converter, or a separate stand alone sub converter. Than at your timestamped video above in #16 ! yeah I get it
    nice and thanks.
  17. Gokhan
    6,714
    2,661
    Paramount CA
    The professor was initially mistaken, but he later corrected himself toward the end of the video:
    • The Gen 4 Prius PHEV has a small “sub” DC–DC converter in the plug-in charger that keeps the 12-V battery at a float voltage of about 13.0 V until the traction battery is fully charged.
    • The Gen 5 Prius PHEV does not have a small sub DC–DC converter in the plug-in charger. However, it turns on the main DC–DC converter in the DC–AC inverter, which aggressively charges the 12-V battery at about 14.3 V until the traction battery is fully charged.
  18. peternumber2
    peternumber2 Member
    134
    36
    Rome
    2023 Prius Prime
    earlier in this thread I asked if there is a way to check if the update has been applied to my car. I'm not sure if anybody answered my question. Anybody knows how to chek?
    thanks
