Weekend charge time
Discussion in 'Prime Plug-in Charging' started by Oldad, Mar 4, 2019.
  1. Oldad
    Oldad Junior Member
    Michigan
    2018 Prius Prime
    The departure charge time throughout the week works great for the kilowatt-hour adjustment. however on the weekends I want to set it to charge at any given time, Saturday or Sunday! I can't seem to accomplish this. Does anyone know how to perform the settings to make an all-day charge event allowing to charge anytime it's plugged in.?
    New prime owner here, thanks in advance for your help!
    52,767
    isn't there a 'charge now' override?
  3. Oldad
    Oldad Junior Member
    Michigan
    2018 Prius Prime
    yes bisco, however if you don't punch the charge now button it will not charge. I thought my scheduling for an all-day charging event you would simply plug it in at any given time, however it doesn't look like that!
    Ol'Dad in da MiddleofdaMitten!
  4. Tideland Prius
    16,668
    If you only have one setting for the weekday, then maybe turn it off until a Sun night? That way, you have no scheduled charge for the weekend.
  5. benagi
    benagi Active Member
    525
    280
    Utah
    I have a set schedule for every day of the week to have the car charged by 8:00am the next morning. But some times I need to go out again later after I get home. So I start the charge immediately by plugging in until the greenl light comes at the plug, then quickly unplug it and plug it back in. This will by pass any set schedule and start charging your car.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I hadn't noticed that. I have seen that, if you open the car door, the scheduler pops up on the small screen and you can use the buttons on the steering wheel to tell it to charge now. But your way sounds quicker.
    benagi likes this.
  7. Oldad
    Oldad Junior Member
    Michigan
    2018 Prius Prime
    Thanks for all your help guys, my issue with plugging in twice to charge is simply wear and tear on that plug. The old Prius used to have a button at knee level to push charge now, sometimes I forget to tap that on the LCD screen and then have to double plug. Kind of disenchanting. Maybe I can suggest to Prius to put that in the next software update!
