Weight limit in trunk
Discussion in 'Gen 3 Prius Main Forum' started by 4rpr15, Jul 20, 2015.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    What is the weight limit for the Prius to avoid so the back end doesn't sag too low while driving? I would like to place 2 big suitcases and 2 small carry ons in the truck. Is this too heavy meaning will the backend look too low while driving? Weight on all 4 (150lb approx) plus 4 people (350) is what worries me.
    '15 Prius Persona-Blizzard Pearl
  2. frodoz737
    frodoz737 Top Wrench
    4,784
    2,549
    33
    If I remember 850 lbs is spec. You will be fine on such a new car. Had about 400 lbs of tools and two big guys in mine once for a 500 mile round trip down line and no problem.
    4rpr15 likes this.
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I've carried over a thousand pounds of slate tile. I also carried about 1100 pounds of wet mulch and 400 pounds of pretty moist soil in the Prius no problem. And that's being conservative.
    4rpr15 likes this.
  4. 4rpr15
    1,056
    375
    WI
    No sagging?
  5. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Also more to your use case, we did a trip recently where myself, my fiancee, and her two friends with a total passenger weight of about 800lbs went for a weekend of skiing. This had 2 sets of skis/boots and winter clothes along with their suitcases for a week of travels (2 large 26inchers and a smaller duffel bag) along with my suitcase a smaller 18inch one and my fiancee's 2 large duffel style bags. All of us went parading around the mountains for a few days no problems. 11,000ft passes, 85mph driving, 8% grades, dirt roads, you name it. The Prius is a beast.
    Everything fit inside the Prius. No roof racks or trailers. Got about 44mpg for the trips which is below normal but pretty darned good.
    4rpr15 likes this.
  6. 4rpr15
    1,056
    375
    WI
    That is awesome. The Prius is a BEAST!
  7. Tideland Prius
    16,660
    825lbs (370kg) is the limit according to the 2010 owner's manual (same generation).
    I've carried a full trunk (and sometimes it overflows to the rear seating area) across the Rocky Mountains over the last few years - a small luggage, a carry-on luggage, a full set of clubs + bag, water, shoes, rackets. One year, I had a set of 4 winter tires and another time, the car bottomed out on a speed bump (oops!). Of course the more you pile on, the lower it gets. It doesn't have a self-levelling rear suspension like certain years of 4Runners do.
    Even with 4 adults and no luggage, it'll look lowered but not saggy. Your 17" alloys will help fill out the wheel well compared to my 15".
    4rpr15 likes this.
  8. qdllc
    qdllc Senior Member
    1,377
    400
    I just got a PM from your car. It hates you. :confused:
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    DO keep in mind with all that weight, the tyres should be inflated a bit higher than indicated on the door placard. I use about 42 lbs front and 40 lbs rear (psi, of course). Also drive conservatively. Your brakes will be working hard as will the tyres. ;)
    I've carried 10 bags of sand (rear seats folded down, bags distributed over the entire area). No sagging, but again, the tyres and brakes are working hard. Drive gently.
    4rpr15 likes this.
  10. ETC(SS)
    7,457
    Asked and answered.
    You'll be fine.
    Good Luck!
    4rpr15 likes this.
  11. Mendel Leisk
    42,195
    If your at max loading the tires should maybe be at max pressure, as embossed on tire sidewall? There's something to that effect stated, on the tires.
    Also, and I could crack the Owner's Manual, but just on my phone: this 850/825 lb. max load, is this in addition to five burly adult occupants? Must be.
    4rpr15 likes this.
  12. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Do you mean 350lb total for 4 people?
    4rpr15 likes this.
  13. Mendel Leisk
    42,195
    I'n picturing four 350 pounders. :)
  14. fuzzy1
    10,675
    No, it is not.
  15. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Right. Lol.
    4, 88lb people.
    Hahaha!!
  16. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Little people are people too! ;)
    4rpr15 and Blizzard_Persona like this.
  17. 4rpr15
    1,056
    375
    WI
    Yes
  18. Mendel Leisk
    42,195
    Yeah, looked it up: 825 lb is all-she-wrote.
    4rpr15 likes this.
  19. David Beale
    5,963
    1,989
    Edmonton Alberta
    The weight listed is carrying capacity, passengers -and- cargo. So load carefully!
  20. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    So if your driving for UBER and get called to old country buffet your limited to 1 or maybe 2 heavy hitters???;):whistle:
    4rpr15 likes this.
