Weight of 15" Alloy Wheels ???
Discussion in 'Prius c Main Forum' started by flotowngtm, Apr 2, 2013.
  1. flotowngtm
    flotowngtm Junior Member
    42
    22
    Going through the threads I have found that the 15" Steel wheels weigh 16.5lbs.
    And the stock 15" Bridgestone tire weigh 17lbs.
    I would like to know what the weight of the 15" alloy wheel??
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I don't recall exactly, but I know this has been found a few times. Maybe try a quick search and see if it shows up on some of the other wheel threads.
  3. mahout
    mahout Active Member
    655
    116
    NC
    Mine weigh 15.7 lb but don't think lighter wheels are the route to better mpg. Tire weight counts 2 or 3 times as much because their weight is farther from the axle. Its about torque.
    Its the reason 195/55x15 tires are slightly less diameter than 175/65x15 tires because they are a couple lb heavier.
  4. flotowngtm
    42
    22
    I dont know where the 195/55X15 tires came into this thread. I know the tire weight counts much more than the wheel weight. But all the 175/65X15 tires are within 2lbs of each other. There is only a few tires that are lighter than the stock Bridgestones. And there only lighter by 1lbs.
    But 15" wheels weigh anywhere from 8-19lbs depending on casting and model. Thats where the saving are at.
  5. mahout
    655
    116
    NC
    The alternate tires for Prius is 195/55x15 and they are a half inch less in diameter than 175/65x15's which helps the mpg stay in the 45-50 mpg range. Wanna see a big change? Strap 205/50x15's on. Its nearly two inches less in diameter but weighs neary 4 lb more.
  6. flotowngtm
    42
    22
    I dont own a Prius so I have to ask. By "helps" you mean lowers right?? From what I have seen the C gets better milage than that.
  7. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    He was probably writing about the regular Prius. People get confused all the time about what forum they are in.
  8. Tideland Prius
    16,678
