Weights attached to frame??
Discussion in 'Gen 2 Prius Technical Discussion' started by Flyin2Low, Aug 15, 2018.
Thread Status:
Not open for further replies.
  1. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Move to Gen 2 discussion?
  2. ITBland
    433
    278
    If real, two contenders:
    Toyota Part No.: 61824-0R010 (Replaces 61824-12050)
    PLATE, NOISE CONTROL
    Part Description Plate, Noise Control, NO.1
    Require Quantity 2
    and:
    Toyota Part No.: 62554-12180
    PAD, PILLAR
    Part Description Pad, Pillar, NO.4
    Require Quantity 2
    Edit: Not so sure these aren't foam pads, not steel.:(
    #22 ITBland, Aug 16, 2018
    Flyin2Low likes this.
  3. Flyin2Low
    Flyin2Low New Member
    NC
    Ok, thanks guys. I wasn't making these claims, another prius owner was. I just wanted your opinion on what the purpose of those parts may have been.
  4. Tideland Prius
    16,658
    Done
    ITBland likes this.
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    mind telling what you took off?
    PriusCamper likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I put my air horn in the space between the condenser and the grille. Lots of room there. Just take the top black plastic cover off the rad.
    Lots of cars use resonance dampening. Some are heavy some are not. On my Crown Vic for example there's a 40 pound weight on each of the exhaust manifold pipes before they hit the cats. There on a pendulum type thing.
    #26 edthefox5, Aug 16, 2018
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And don't you think it is obvious that I think it is BUNK ??
    Well just for the record, it sounds like a TROLL.
    Do I need to explain what a troll is ??
  8. Mendel Leisk
    42,191
    Some one that's argumentative?
  9. BuickGN
    BuickGN Junior Member
    25
    48
    Los Osos
    Additional weight in the form of.... well.... weights hung off the frame will do nothing for safety and have the potential for making it less safe. Many cars have weights bolted to the frame and many times it's in front of the front axle-line and as far forward as the frame goes, and many times with a rubber damper on it as well to help damp oscillations. I removed the one on my Acura TL and in park there was no difference but at idle in drive, there was a small bump in vibration in the cab (extra load from the drag of the converter). Once the AC kicked on in drive, there was an unmistakable increase in vibration in the cabin. This damper was not included on the manual transmission models, since they lacked the additional load of the converter at idle in drive at a stop. This could also be to damp frame/body oscillations in certain conditions. Sometimes just the right combination and type of bumps can make the chassis ring and the weights can lower its resonant frequency.
    #29 BuickGN, Aug 16, 2018
  10. PriusCamper
    PriusCamper Senior Member
    13,335
    5,395
    Pacific Northwest, USA
    On the internet?
    Oh my...
    So uncivil.
  11. PriusCamper
    13,335
    5,395
    I think these steal plates really are for sound deading! And if a little weight works, why not a lot? So I went to the gardening store and loaded up and I can say for certain, that the car does indeed ride quieter now. I think I'm just gonna put blankets over the pavers and call it done. Car is way quieter now! Way more fun!
    https://priuschat.com/attachments/image-jpg.73242/
  12. Tideland Prius
    16,658
Thread Status:
