Weird and frustrating. Oxygen sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alanwagen, Mar 14, 2019.
  1. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    RE: 2010 Red Pruis with 103k miles.
    Weird thing happen. I was gone a week and coming back from the airport. As I was driving home from the airport, the check engine light came on. Wth??. The next day I went to O'reilly's Auto parts and they pulled the codes. Both Oxygen sensors bad. The Upstream and downstream. How weird is that?
    I took it to the dealer and the got the same codes but they thought it was just the downstream and replaced it. No dice. They had to replace both. They thought it was weird also. I had a coupon so it was $585 out the door, not too bad as the parts are high.
    Any ideas what could of caused that and/or has anyone else experienced this???
  2. Mendel Leisk
    40,584
    Maybe a failing 12 volt battery causing false alarms? Good thing to check first.
    @bisco better put a like on this...
    RMB and Raytheeagle like this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Oxygen sensors are big money makers
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Excellent fill in advice(y).
    RMB and Mendel Leisk like this.
