Weird burning smell coming from engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jarrad reddick, Jun 17, 2026.
  1. jarrad reddick
    jarrad reddick Junior Member
    23
    atlanta
    2012. Just looking for feedback as to some things I can check. No codes. Things seem fine otherwise. Just changed spark plugs (with assistance). Worried that trouble is looming…
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,349
    980
    Monument, Colorado USA
    Could be a number of things....something as simple as motor oil or coolant getting spilled on the exhaust can cause a smell when the car is running.
    It's good you don't have a check-engine light.....do you get any black dust on your finger when you rub it inside the tailpipe? (If it's burning oil, it will be black.) Do you see any smoke blowing out of the tailpipe when you accelerate at lights? (White or blue or gray or black smoke?)
    I'd carry a good light and if I smell anything I'd pull over, pop the hood, and look all around for the source.
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I would begin with an inspection of the exhaust system. The scenario is plastic garbage from the road lofted and applied to hot exhaust components.
    ASRDogman and ColoradoBoo like this.
  4. JC91006
    16,936
    8,647
    Just changed spark plugs.....that's always a clue to why suddenly something is different. If you didn't use OEM parts from the dealership or reputable seller, you most likely bought fake parts that can cause issues, like the burning smell. Did you replace the coils too?
  5. Mendel Leisk
    42,348
    Anything untoward prompt the spark plug change, or it was just time? What's the miles on it btw?
    I concur with @JC91006: a recent maintenance is a possible cause of new symptom.
  6. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    The source of a smell can be deceiving.... I thought I smelled electric burning from engine compartment once and it turned out to be a battery pack behind back seat.
