Weird door lock state
Discussion in 'Prime Technical Discussion' started by PiPLosAngeles, Feb 24, 2019.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Last night I went to get in the Prius and when I touched the door handle it didn't do the usual two-beep unlock. Instead it rapidly alternated between unlock/lock 4 or 5 times in the span of 5 seconds or so. I wasn't touching the "lock" spot. Lots of beeps. I couldn't even get the door all the way open because it locked again half-latched. It took a little bit to get it open. I could reproduce it at will standing there in the parking lot, but after I drove it home I haven't been able to get it to happen again. Has anybody seen that before?
    52,391
    12v?:D
    iirc, someone else has a thread on similar problem. not sure what prius.
    her door would open a quarter in or so. i think they replaced the guts, but not sure.
  3. Mendel Leisk
    41,905
    On a previous car I had the latch mechanism click into the closed position, while the door was open. I'd been messing with it, can't recall exactly how. Then it wouldn't close properly.
    I was stumped, taped the door shut, and drove to dealership. Mechanic showed me how to toggle it back with a screwdriver.
    Maybe something like that?
  4. PiPLosAngeles
    1,551
    724
    It may have been something weird with the door being half-closed, but the mechanism wasn't latched while the door was open.
  5. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I've had the door get "confused" before. this has happened a couple times where I ultimately had to use the key-fob unlock to get the door to unlock all the way to open it up. seems to be entirely random, and very infrequent.
  6. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    I had the same happened a couple of times.
