Weird noise from front
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priusfan2008, Jan 17, 2013.
  1. Priusfan2008
    Priusfan2008 New Member
    Hi everyone,
    I bought a toyota prius 2008 standard model few days back. Car is like new and has 35000 km run . Before buying the car I got full service from Toyota show room. I have a temperature of -7 to -15 degree centigrade now a days. I live in hilly area and covered with snow. For last couple of days when I come down from a slope I hear weird sounds from front end of my car. Especially when I take out my car from my garage in reverse mode start to go down to a slope immediate in front of my garage. What it can be? Can it be brake pads or other things? Please note that toyota performed all necessary service and tests and all was OK.
    I look forward to hear from you soon.
    Thank you in advance.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, it is your brake pads. Regen braking doesn't work in reverse so it relies solely on the brake pads/shoes. You are likely hearing the shoes rub against the braking surface.
    You will likely hear other sounds that you're not used to with the Prius. The main reason you hear them is b/c the Prius is so quiet, it does not drown out these sounds like other cars do.
    Priusfan2008 likes this.
  3. daveprius09
    daveprius09 Junior Member
    Ivyland, Bensalem, Pennsylvania
    does the noise happen when torquing up drivetrain - pulling out of garage etc? On my 09 I have found that the exhaust flange mounting springs will sometimes squeak instead of gliding freely while the engine/transaxle is moving/torqing up. It can be annoying. One way to tell is to raise vehicle and wiggle front down pipe (while pipe is cool so you don't get burned). If that is the noise, you will clearly hear it. Sometimes you can wiggle it alot & the noise will temporarilly go away. If it is that, you can brush a small amount of high temp anti-seize compound on springs and slide bolts. I have had one of my customers who has a 2006 had the same problem. I also did the same thing for him as with my 2009. Let me know how you make out. Dave
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Welcome to PC.
    Very common complaint especially if you just bought the car and it has sat on a lot for a while.
    You have corroded front brake rotors.
    Please look through the wheel spokes and examine yourself. Since the fornt friction brakes hardly get used due to regen there's not alot of hard rubbing of the rotor to disc. And that allows rust to build up quickly and deeply on the rotor surface. Most cars have pristine shiny rotors from wear. Prius's are always rusted. That makes for quite a racket when applying the brake slowly. Especially in reverse. Really loud in reverse. Since your new to the car get used to cleaning the rotors once in a while:
    Get up to speed around 50 or 60 make sure no ones behind you or in front of you and put the car in neutral. Apply nice firm braking. Not hard just firm.
    Repeat. Then put the car back in D and drive on. Do that once a day if you can. It removes the surface rust on the rotor. The rotor will still be rusted though.
    Putting the car in neutral does not allow regen to engage so you are on friction brakes only.You will be very surprised how poor the Prius brakes are by themselves. Also if not maintained the brakes get incredibly grabby especially after a rain.
    Like any car you own putting this car in neutral while driving with practice should become second nature. Best defense for a run away car.
  5. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Mine did that to. Weird buzzing. All you have to do is tighten the nut on that spring flange. It comes loose from the super heat and then cool off, super heat etc...
  6. bisco
    52,433
    does it only happen when you apply the brakes?
  7. Priusfan2008
    When I took my car out in reverse from garage then due to immediate slope I have to apply brakes and I heard this noise but now for last couple of day, I did not hear an noise. Outside temperature has also came down from -18 to -3 degree centig. I think it may be due to very cold outside.
  8. Priusfan2008
    Thank you very much for the reply. But now the noise has gone itself. I do not know what was the reason?
  9. Priusfan2008
    Hi thank you for the reply and advise. But for last couple of days, the noise has gone and its ok now. May be due vey low temperature -18 degree cent, it happened. But any way, if it will happen I will do the same.
  10. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Your welcome.
    Comes & goes depending on how humid it may be. Look at your rotors with a flashlight and see how rusted they are. No matter what you will still have to do what I suggested though.
