Weird Overheating Issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JimJitsu, Aug 21, 2023.
  1. Rrrolfff
    Rrrolfff Junior Member
    77
    Irvine
    Wondering why that would matter
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Somebody read Mad Magazine as a child.....................and still does!!
  3. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    I edited my post #20 by adding "I know this is not related to your overheating problem, I am just curious."
  4. Brian1954
    2,694
    1,077
    I commend you on your troubleshooting process to monitor both of the temperature sensors.
    My guess is that you still have some air trapped in the exhaust heat recovery coolant loop or what ChapmanF wrote in post #17 about the exhaust heat recovery thermostat maybe being the problem.
    Can you please tell us in detail the process you used when you refilled the coolant and how you tried to bleed the air out of the engine coolant system.
    #24 Brian1954, Aug 22, 2023
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    I checked my car tonight.
    7C0 is the Exhaust Heat Recirculation Coolant Temp Sensor.
    The Exhaust Heat Recirc piping cools off much faster than the engine block/head sensor and stayed 4-5 degrees cooler when the engine was fully warmed up.
    #25 rjparker, Aug 22, 2023
    xliderider and Brian1954 like this.
  6. JimJitsu
    JimJitsu Junior Member
    16
    Ventura, CA, USA
    New coolant (pink).
    Brian1954 likes this.
  7. JimJitsu
    16
    Ventura, CA, USA
    1. Filled the tank.
    2. Waited a few minutes for the coolant level to go down.
    3. Filled it again (may have repeated this a couple times...don't remember).
    4. Started it in maintenance mode.
    5. Waited for the fans to come on (took about a half hour).
    6. Turned off and topped off the coolant.
    7. Had to top it off again after driving after the first day.
    If this wasn't sufficient, what else could I do now?
    #27 JimJitsu, Aug 23, 2023
  8. JimJitsu
    16
    Ventura, CA, USA
    Thanks! At least that mystery is solved. Unfortunately, there is a LOT less information on here (or anywhere else) about troubleshooting when that sensor is causing the light than for the block sensor.
    After watching the temps the last 24 hours, the block temperature still behaves normally. However, the other one fluctuates wildly after its initial rise, even continuing to go up at stop lights. After about a mile on the freeway, the temperature starts shooting up. I let off the gas and drop to about 60 mph and it pauses, goes down and up a couple of times, then drops quickly. Usually at that point, no matter what I do I can't get it to climb like that again or overheat. However, it is usually 10-20 degrees warmer than the block sensor, though it will sometimes dip below it before rising again.
    I'd like to believe it's just the sensor going bad and not something more concerning, but I'd imagine it wouldn't be misbehaving this consistently after the first mile on the freeway if it was just that.
  9. rjparker
    11,140
    6,985
    Texas Hill Country
    Radiator cap on or off? I have done mine at least twenty times always with the cap off to release air.
    Typically thermistors do not intermittently go higher on their own. Usually they open circuit or short. Even a bad connection normally won’t reduce accuracy by more than 1-2 degrees.
    A quick check with a low cost infrared thermometer verifies the sensor against your scanner. Easy. My sensor was within three degrees of the scanner.
    If the sensor checks out, odds are the piping at that measurement point is getting hotter. The flow diagram in post 25 suggests the Exhaust Heat Recirc valve may not be opening. If so, the coolant may be getting hotter.
  10. ChapmanF
    19,058
    As you have a Gen 3, which has a degas-bottle cooling system, there is a fairly straightforward procedure in the manual. When you look at the degas bottle, you will notice there is a line marked B, up above the line marked FULL.
    When refilling a system, you fill right up to the B line, cap the bottle, start the engine, and run it long enough to be pressurized and hot, and several minutes after that. Some squishing and shaking of hoses is involved. Then you turn it off and wait for everything to cool.
    Once everything has cooled back to ambient temperature, you look at the bottle again and see the level dropped down to the FULL line. The extra coolant in the bottle traded places with the air in the cooling system. The distance from FULL up to B is the amount of coolant the engineers knew it would take to do that.
    All that said, I suspect "trapped air" gets blamed for strictly more cooling system issues than it's really capable of explaining, and this is probably the kind it wouldn't explain very well.
    It's a thermistor sensor and those don't go bad a lot.
    There's some troubleshooting information in the section of the repair manual for trouble code B1503; that's the code the combination meter sets if that temperature reading looks unreasonable. That sensor is wired straight to the combination meter, which is why it gets a B code instead of a P code like you'd expect to see from the engine.
    The instructions for checking the exhaust flow control valve and its thermostatic actuator are earlier in the manual. That stuff is pretty easy to see, once you're under the car.
  11. JimJitsu
    16
    Ventura, CA, USA
    The reservoir cap was off the whole time.
    I'll try the thermometer test, but it sounds like the chances of it being a sensor are almost nil?
    Any sources for how I can troubleshoot/check the valve?
  12. ChapmanF
    19,058
    Toyota Service Information and Where To Find It | PriusChat
    The rod should be at least 7.2 mm further extended at operating temperature than at ambient.
    That's probably ok, though if you ever do it again, to follow the manual you would have the cap on, so the system can reach pressure and make the bubbles smaller to work their way out.
  13. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You should also fill VERY SLOWLY.... A little at a time.
    This allows the coolant to settle and push the air up and out.
    If you fill slowly, eventually to the "B" mark on the tank. Let it sit for a few minutes then
    top it off, you'll notice that it is at the full mark after it runs for a few minutes.
    What I have done on my Prius is start the car, after filling coolant, let the engine run until it shuts off.
    Check the level and it's right at the full mark. Then I drive the for a mile or two close to my house.
    Then I park it level, clean everything up and then check the level. The 4(?) times I've it it has been at the
    full mark or just below. I fill it just past the full mark and it stays there.
    I've neve had an over heating problem.
    Filling it fast traps the air.
  14. JimJitsu
    16
    Ventura, CA, USA
    I was finally able to inspect the actuator under the car and it didn't really tell me much. I put it in maintenance mode and it slowly came up to temperature. The rod did slowly extend what looked to be about 7.2 mm once it warmed up after about 20 minutes.
    So as it stands now, I can drive it all day on surface streets no problem. However, it overheats every time I drive it on the freeway more than a few miles after starting cold. The temp will eventually climb 10-20 degrees at a time rapidly and as soon as the secondary coolant sensor hits 248 degrees, the temp light comes on. I back off and slow down and it goes off once I hit 236 degrees. It then starts to steadily go down until it settles at around 206 degrees. At that point, I am unable to get it to overheat again, no matter how fast I drive. The primary coolant sensor on the block barely ever gets to 200 degrees and behaves as expected.
    So, my operating theory is that there is something wrong with the thermostatic actuator to where it is working, but opens too slowly to keep up with the rise in temperature from highway driving. Once it eventually gets all the way open, it behaves as it should and I have no problems again until after it cools down and closes again. Thoughts on this?
    Also, if my theory is correct, then I need to change the actuator, but since I can't seem to find any videos or guides (other than the service manual) on this repair, I'm not totally clear how the actuator works or what I need to replace.
    There's the actual actuator (#17495), the actuator case (#47010), a stopper (#17496) and a gasket (#17499). Is there a chance that the problem is with the rod in the case and not the actuator? Should I replace all of these parts (the manual does say to change the gasket when changing the actuator)?
  15. rjparker
    11,140
    6,985
    Texas Hill Country
    I would bypass the coolant hoses to the exhaust and try it again.
  16. Brian1954
    2,694
    1,077
    I do not think that this helps very much in the diagnostics of his problem. It will only prove that coolant flowing through the exhaust heat recirulation loop does not get hot after you do the bypass. It will not prove that the actuator is sticking a little during the warming up phase.
  17. Brian1954
    2,694
    1,077
    I agree with your theory that the actuator is sticking a little during the warmup phase. Is there a way to keep the exhaust flow control valve in the open position? If so, try it and test drive the car and watch the coolant temperatures.
    I would replace all the parts in the actuator assembly. You only want to do this once.
    EDIT: The exhaust flow control valve maybe is not opening smoothly when the actuator is trying to open it. It might not be a sticky actuator.
    #37 Brian1954, Sep 3, 2023
  18. rjparker
    11,140
    6,985
    Texas Hill Country
    I would bypass as the repair.
  19. Brian1954
    2,694
    1,077
    OK.
    If you do the bypass, then the exhaust flow control valve will not open in the exhaust pipe. Will this cause any problems in the long run?
  20. rjparker
    11,140
    6,985
    Texas Hill Country
    You could replace the actuator and heat exchanger (valve is likely carbon clogged), force the valve open with a clamp or forget about it.
    I would not buy parts until I knew the bypass fixed the overheat issue. The temperature sensor has not been verified or there could be a serious engine cooling issue.
