Weird Overheating Issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JimJitsu, Aug 21, 2023.
  1. JimJitsu
    JimJitsu Junior Member
    16
    Ventura, CA, USA
    Interesting. I do live in SoCal, so any benefit from the EHR system does seem negligible when it rarely goes below 50 degrees and is almost always above 60 here.
    1. This may be a dumb question, but how do I join the two hoses together? It would seem I'd need some sort of joinder part to clamp both of them to?
    2. I would assume this would totally drain the system of coolant, right? I only ask so that I have enough on hand to refill afterwards. Though I suppose I could just capture it from the hoses and put it back in?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    If the system is bypassed I might expect it to turn on the check engine light since the heat exchanger is there for emissions and the temperature sensor is there to confirm proper operation.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    I would get it up high enough to inspect it, measure the existing metal hose connection, decide if the two hoses are long enough to directly connect and then buy a hose kit like this $6 Amazon set or directly from an auto supply for a little more. If you need an extra piece of hose get it locally. Two vice grips could clamp off the hoses while you work. IMG_2818.jpeg
    Worse case your out ten dollars and you have some stock for the hardware drawer. Beats a $150 diagnostic at the dealer.
  4. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Seems to me that you probably have air in your system. Or a faulty thermostat.
  5. JimJitsu
    16
    Ventura, CA, USA
    It would seem like clamping the actuator when it's open would be the simplest way to test this. Would just a paper binder clip do the job (I assume there's not much force involved pulling it back in)?
    Also, the way the actuator/valve works, is it possible the actuator is moving/opening but the valve inside isn't (again, I only barely understand how this works, so forgive my ignorance)?
    wukong sun likes this.
  6. JimJitsu
    16
    Ventura, CA, USA
    Is this possible that the actuator opens, but the valve doesn't? Where is the valve located?
  7. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    The exhaust heat recovery system is all new to me. I am learning just like you are. The Exhaust Flow Control Valve is located inside the exhaust pipe.
    Based on the flow diagram in post #25, I am guessing that the Exhaust Flow Control Valve is closed when the car is cold and the Exhaust Pipe Gas Control Actuator Rod is retracted. This allows the exhaust gas to be diverted through the heat exchanger and heats up the coolant which then circulates through the engine to heat the engine quicker. As the coolant increases in temperature, the rod on the exhaust pipe gas control actuator is extended and the rod is used to open the exhaust flow control valve. I have not physically looked at my car to see how this works, but you said in one of the posts that you observed that the rod on the actuator extends when the car warms up.
    Take a look at your car to see if the rod on the actuator pushes a lever or is connected to a lever that would rotate and open the exhaust flow control valve.
    I have been reading all the new threads in the Gen 3 section of this forum the last several years, and this is the first time that I can remember a problem like you have.
    EDIT: See the first half of post #32 by ChapmanF. He says the manual tells you how to check the actuator and the valve.
    #47 Brian1954, Sep 3, 2023
  8. rjparker
    11,140
    6,985
    Texas Hill Country
    You need something much stronger than a binder clip
  9. ChapmanF
    19,058
    Because the actuator is one of those expanding-hot-wax deals just like a thermostat, one of these "what happens when an irresistible force meets an immovable object?" questions comes up. As the actuator warms, its wax is going to expand and that rod is going to extend, unless something physically broke in the past and the wax burst its containment.
    And if that rod is still pushing a lever effectively connected to the valve, the valve is going to open, unless it is so seized that the rod has pushed the lever off the shaft, or twisted up the shaft,, or bent the lever out of the way.
    Those are the kinds of things I'd be looking for,
  10. rjparker
    11,140
    6,985
    Texas Hill Country
    Apparently no codes based on a recent bypass.
    It’s very likely the valve is caked with carbon since it is located within the exhaust.
  11. mr_guy_mann
    4,120
    2,018
    NJ-USA
    I would be interested is seeing what exhaust backpressure is at the downstream O2 sensor port with the valve closed vs open. But not too many folk have the gear (as simple as it is).
    Brian1954 likes this.
  12. JimJitsu
    16
    Ventura, CA, USA
    I potentially found the problem. This weekend, I jacked the car up on the passenger side so I could inspect the "exhaust flow control valve". I was able to move it slightly with a screwdriver, but definitely couldn't generate enough force to open more than a few mm, much less all the way. Given the size of the spring holding it closed, I assumed this was normal.
    Although the actuator is able to push the valve open and doesn't seem to have any problem doing so once it comes to temperature, it looks like it might not be opening as fast as it should (or possibly not the whole way), as I already expected, because of the added resistance. Unfortunately, the repair manual says if the valve "does not move smoothly," the only thing it suggests is to replace the entire front exhaust pipe assembly.
    This video is the closest thing I could find to an example of this valve opening: Video. At 2:50, he appears to be able to easily open and close the valve with his fingers. (This video does deal with a Gen. 4 Prius, but I assume it would be the same as on a Gen. 3.) Does anyone have any experience testing this valve? Should it normally open easily with only a little pressure?
    I think I will have try the bypass method outlined above next.
  13. rjparker
    11,140
    6,985
    Texas Hill Country
    Get it up to temperature so that the valve is open and clamp it or otherwise secure it open. I would do that first and bypass second if that was not enough. No binder clips.
    #53 rjparker, Sep 11, 2023
    JimJitsu likes this.
  14. JimJitsu
    16
    Ventura, CA, USA
    That was the first thing I wanted to try, but I can't see any way to clamp it open. Maybe clamping the actuator rod while it's extended to hold it open, but not sure what I would use to do that either that wouldn't damage it.
  15. ASRDogman
    8,070
    4,092
    From what I've read, it fails internally. I don't think it was welded correctly or well enough
    and it leaks. A defect that I believe Toyota will warranty.
    And ALWAYS filter the coolant if you're reusing it! Who knows what crap is in that system now.
