Weird plumbing problem
Discussion in 'Fred's House of Pancakes' started by qbee42, Apr 10, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    For some reason, I just can't picture you in fatigues, carrying a 16. Really, I can't
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Beginning in the late 80's, all the major IC makers abandoned the rad-hard and rad-tolerant IC market. It was left to small scale, dedicated foundries (e.g. Honeywell, Hughes, etc.) to provide the Silicon-On-Saphire and other materials for satellite and niche markets. Intel was the first to leave and then once TI left, most military electronic specifications no longer required anything in the way of rad capable requirements.
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    My parents in FL had a problem with pinholing in piping under
    the concrete slab, as they build almost all the houses down there.
    Under-slab leaks are rampant, in fact, especially around certain
    vintages [relatively recent] of construction, where they probably
    started cheaping out and using L grade pipe instead of M [or
    maybe I have that backwards]. Anyway, the fix was to chop it
    all off short and redo everything with PEX through the attic.
    Having just recently tooled up a little to do small copper jobs,
    I'm loath to go the PEX route yet especially with the crimp tools
    being priced as they are. Fortunately my own neighborhood seems
    to have a lot of iron in the water but relatively few corrosion-
    causing minerals. It just discolors the toilet bowl fairly fast.
    _H*
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    There is a reason that you can't picture that. I did say *draft* card.
    Tom
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    Having involvement in certain projects, I will say that tactical, mission-critical systems still have the requirement. Eg fly-by-wire absolutely requires it
    There are specialized manufacturers
    http://www.mskennedy.com/client_images/catalog19680/pages/files/MSK106RHTotalDoseTestReportrb.pdf
    that not only make a line of rad-hard components, but provide TID reports up to MIL-STD-883
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Just curious, are you going to use the reliable but illegal 50/50 solder, eg have some ratholed away? The illegal solder works *much* more reliably than the new stuff
    I know what you mean about the price of the tools. I paid around $200 for the kit, the head can take 1/2 and 3/4 dies which is the only size I'd be fooling with
    As I'm sure you're aware, an "iron filter" solves one problem but tends to introduce another problem, especially the potassium permanganate
  7. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Couple of finer points:
    1) Yes, certain projects do require it, that's why I said most.
    2) Those that do require it are limited to processing capabilities of two decades ago. The F-22 flight control system is at a i386 level of processing. The software compilers used are ancient. Good enough to work, but very difficult to recruit young software engineers to stick with, since they see it being unmarketable outside of that (shrinking) area.
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    I agree, part of the problem is that extremely high density IC's have a long way to go before they can deal with the TID's that one can expect from either HAEMP or very close nuclear detonations
    eg prompt ionizing radiation will reliably introduce latchup in even "certified" systems. Hot restart groups can deal with that, if they are properly programmed/sequenced
    There are obvious limitations to overall system capability for an airbourne system vs a land system. Eg C3I systems will usually be COTS, but protected by enclosures, even entire rooms, with special design to resist HAEMP.
    It sounds like we have worked on similar projects and systems
    If you're referring to the compiler I'm thinking of, I wouldnt exactly label it as "ancient." Not fancy to be sure, very little application on the civillian side, especially the entertainment industry
    I often hear the frustrations you mention from the younger folks. Not sure what they're moaning about, I've been doing this sort of work since the mid 80's and always seem to drift back into it.
  9. qbee42
    18,058
    3,081
    Northern Michigan
    I remember one of my programmers telling someone that he was "a dinosaur in training."
    Tom
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, sure. If you don't keep up with the technology, after 2 years you're automatically "ancient" anyway
  11. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    duct tape and rubber bands are the bestest fixes
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    That is SO true
    Main Menu
    especially the part "if women don't find you handsome, they should at least find you handy"
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    One of my favorite Red Green clips was the Poor Mans Power Window Conversion
    Just the ticket, I pull up in an old used up rusted out s***box Dodge van, pop the mixer onto the protruding stud, and zzzzzzzp
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    I somehow picture Tom's first car being just like this one
    I know mine was pretty much like that, duct tape and all
  15. hobbit
    4,089
    469
    Bahstahn
    Okay, I've now been indoctrinated into awareness of the Red
    Green show.
    Yeehaw...
    _H*
  16. qbee42
    18,058
    3,081
    Northern Michigan
    Keep your stick on the ice.
    Tom
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    And here you thought there were no hillbillies in Canada.
    Silly boy ...
  18. qbee42
    18,058
    3,081
    Northern Michigan
    Somehow Canadian hillbillies seem more lovable. Perhaps that's because I live in a northern state.
    Tom
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    They use a lot less chew, and tend not to drive around with high power rifles
