Weird situation - I could use some help
Discussion in 'Generation 1 Prius Discussion' started by WHCSC, Jan 18, 2017.
  1. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Daughters 2002 Prius with about 145K. Has very little power. Has to be pushed around the mechanics lot. No lights came on and no codes come up. I had just changed the oil while she was home from school. I put 3.5 quarts in. Boyfriend drove it back last weekend (about 100 miles) when this happened. Mechanic said it had 6 quarts!!! He drained some out but same issue. Any ideas??
    #1 WHCSC, Jan 18, 2017
    52,878
    hybrid specialist with tech stream diagnosis software?
  3. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    It's being done as we speak.
    52,878
    maybe they'll find codes.
  5. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    I'll post the findings
  6. bisco
    52,878
    all the best!(y)
  7. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    In general could having that much extra oil in it cause the issues described? Would it throw off the ECM?
  8. bisco
    52,878
    yes, too much oil can be very damaging, can even blow the engine seals.
  9. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    It could seriously damage the engine. Blow seals, bearings, rods and pistons. I've seen this happen on a combine motor--mopar 383 propane--the mechanic got distracted and put in 5 quarts, but had neglect to drain 5 out. Strange that your daughter's car even made a hundred miles. The high price of trying to do something nice. . .:(
  10. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    I'm not sure how or when the extra oil was added. Hopefully it wasn't run with it in there.
  11. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    So mechanic says it was filled with diesel and all the cranking to try to start it drained the main hybrid battery. Does that sound legit? He says that a dealership can recharge it. Is that true?
  12. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Ouch! So it was too much oil! Just not, what we imagined.
    Yes.
    Yes. Chargers are shared around the dealerships, so there could be some delay in getting the HV battery charged.
    Who is going to do the remediation of the fuel system to remove and clean out the diesel?
  13. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    The mechanic said he siphoned the diesel out through the fuel rail and put gas in. The extra oil is still a mystery. Nobody is admitting to adding it. Fingers crossed for a battery that is not damaged too much to be recharged.
  14. Patrick Wong
    18,210
    6,526
    I doubt that your local Toyota dealer is going to be able to recharge the battery. It is 15 years old.
    I suggest it is time to help your daughter figure out how to fund $3K for a new battery, or else develop plans to acquire a different vehicle.
    I'm just wondering how it was possible to add diesel fuel to a gasoline vehicle. The diesel pump dispenser has a much larger nozzle while gasoline vehicles have a narrow opening which is intended to prevent such an occurrence, so the person who did this had to be highly motivated... Unless the gasoline station had the wrong fuel stored in the storage tank...
  15. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    The gas station admitted to having diesel in the wrong tank. Thank goodness it is in a very small town so only a handful of cars were effected.
    The battery was replaced with a new one 3 years ago. Does that mean it should be able to be recharged?
  16. Patrick Wong
    18,210
    6,526
    Maybe. I hope the gas station is going to cover your repair bills.
  17. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    I would talk to the good lawyer and require all ongoing repairs and rental covered.....
  18. Samprocat
    491
    297
    Lincoln, NE
    I have many years ago same problem with big Truck where they have Gas instead of Diesel...and i have come after company where i filled and they eat up 45 000 dollars in labor and new engine and my loss of work till they finished......so i will advise you to seek professional help to be represented in Court
  19. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Gas station has agreed to cover all costs to bring the car back to it's condition before the incident. New battery and anything else required. Fingers crossed.
    Aaron Vitolins likes this.
  20. Samprocat
    491
    297
    Lincoln, NE
