Weird stuff happening? MPGs dropping? Test The Battery
Discussion in 'Newbie Forum' started by richard schumacher, Dec 13, 2009.
  1. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I'd say your 12V battery is OK, it could use a bit more charging but it isn't dead yet.
    I'm not sure what to say about your HV battery. I'll leave that for someone else or another thread.
    Shahzad and richard schumacher like this.
  2. tvspaulmoore
    tvspaulmoore Junior Member
    37
    Dunedin, FL
    I have posted these results in a separate thread but wanted to add here just in case: I have an 07 with 76k miles here in FL. Have noticed a recent sudden drop in MPG from high 40s to mid 3os and can't work out why...
    The voltage reading just now (it was driven an hour or so prior) was 12.3 in the unload mode and 11.9/12.0 (checked twice) with load applied (having pressed the power) and 14.3 with the engine started & idling
    Does this sound like a battery about to die? Would it explain low MPG?
  3. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    Join the club. Mine went from 50ish to 42ish for a couple of months recently, and now it's back to 47ish. Can't correlate it with much of anything. I'm wondering if there's some drag in the drivetrain -- subjectively, I feel that when I come off the accelerator the car slows down much more rapidly than "normal", and certainly more rapidly than my wife's '12 v. Time for some real measurements.
  4. Asim Jahangir
    Asim Jahangir Junior Member
    34
    I have a Japanese made Prius 2007. Can't use the same procedure to enter maintenance mode since there is no info button on the MFD. There is info button on the steering, which is used to switch between the hybrid info and driving/mileage history modes. I tried using that while switching the lights on and off but didn't work. Any tips?
  5. dhanson865
    851
    188
    TN, USA
    If you can't use the MFD or lights to do it just grab a cheap multimeter. I use this $20 meter amazon.com/gp/product/B0012VWR20 but you can use anything with 2 leads similar to that.
    It doesn't let you sit in the drivers seat while testing but it's scientifically accurate and not that inconvenient. When I use the meter I open the hatch, pull up the rear cargo mat, turn the meter to 20v and touch the battery leads. Measuring directly will give you a couple of tenths higher reading vs what you'd see on the MFD but the difference between a dead battery and a good one is much higher than the .2 to .3 you'll see between the two methods.
  6. Gorilla97
    Gorilla97 Junior Member
    110
    Edmond, OK
    With the weather turning much colder today I decided to check my battery after my 20 minute commute home. Looks like I will start looking for a new yellow top Optima battery as I'm pretty sure my 2008 still has the original 12v battery.
    From the test procedure....
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery) ......mine read 11.2v
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V.......mine read 11.1v
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)....mine read 13.9v
  7. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Asim Jahangir likes this.
  8. dhanson865
    851
    188
    TN, USA
  9. gd420mj
    gd420mj Junior Member
    RTP, NC
    Omg. Thank so much for posting. I was dreading $190 for battery when i saw 160 last year.
    My story, my 06 with 178k miles is still original battery. About 4th time died in about 10-11 months. Sometimes I get key left in fast beep, but it doesn't always kill battery beyond startable. Checked V this afternoon at work, was under 11V. Watched it as I started and dipped to 9.3. But I drive my car every day and it will probably start in morning. Am I pushing my luck? Battery is a month away 7 yrs and has 178k miles. I was hoping for 200k..ha! Car was originally sold in NJ, I bought in 8/11 and just came to NC with it. (We had a cold weekend)..
    Is it true a weak 12V can cause Ecu to lose driving habit memory? I didn't think this car learned habits. My mpg's are still above 46 mostly and only dropped immediately from 50's after new tires last year. Still I wonder if mpg's will Improve with a new battery. Mine never really died dead, just a bit too weak to fire those contactors.
    Turn off signatures in Tapatalk Tapatalk
  10. Gorilla97
    110
    Edmond, OK
  11. gd420mj
    RTP, NC
    Hey there. Did ya print to PDF by any chance? Page won't load now. It just did then almost full blank product page. Hope it wasn't pulled?? Ahh!! Earlier it said to call for my area.
  12. Gorilla97
    110
    Edmond, OK
    I can scan you a copy just message me your email
    gd420mj likes this.
  13. Gorilla97
    110
    Edmond, OK
    For anyone else that is interested here's a PDF of the screen shot I was able to print off last night. Not sure if Pep Boys will match the price as listed but it's worth a shot.
    Good luck!
  14. gd420mj
    RTP, NC
    Seems optima yellow top battery for prius is discontinued. Called pep boys and that's what they said. No Prius on optima website. ...oh no!!e
  15. Gorilla97
    110
    Edmond, OK
    I placed an online order for pick up and just received an email saying the battery is ready to pick up. Hopefully I can get away at lunch hour and get it. Total price with core charge and tax was right around $154.
  16. dhanson865
    851
    188
    TN, USA
    I can't imagine it being discontinued. They still have it on amazon direct from optima and other sites still have it such as
    Optima DS46B24R Yellow Top Dual Purpose Battery
    Optima (8171-767) DS46B24R Yellow Top Prius Battery : Amazon.com : Automotive
    if you have Amazon prime its about the same either way $170 after shipping
    Prius Auxiliary Battery DS46B24R Yellow Top Optima has it about $10 cheaper with free shipping.
    if you want to see it on the optima website it is at DS46B24R YELLOWTOP® Prius® Auxiliary Battery 8171-767 :: OPTIMA® Batteries
    not sure why you couldn't find that when you searched.
  17. Gorilla97
    110
    Edmond, OK
    I went to pick up my battery at Pep Boys but decided not to buy it. The battery looked used (dirty) and the parts guy told me something was spilled on it on the delivery truck. I'm not in dire need for a replacement so I'm going to try my local Advanced Auto Parts store tomorrow and see if they'll price match the Pep Boys price.
  18. Asim Jahangir
    34
    I got my old battery charged using a charger and worked fine. Thanks for all the help.
  19. Thump553
    Thump553 Junior Member
    CT
    2020 Prius Prime
    Excellent thread, just checked the 12v battery in my 2008 Prius, 116k miles, original owner and got 12.1v, 11.8v on load. No issues yet but mileage has slipped recently and ICE is on almost all the time so I'm springing for a new battery via Amazon.
  20. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Q: So, the general consensus is that the Optima Yellowtop 'Deep Cycle' battery is the BEST replacement battery choice?
