Weird tire wear
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gen2Prii, May 29, 2022.
  1. Gen2Prii
    Gen2Prii Junior Member
    24
    South Florida
    I'm trying to find the solution to the uneven wear on my rear driver side tire. At low speeds, the rear end of the car is wub wub shaking.
    There is no steering wander, I think the front is toed correctly, it's just the rear giving a problem.
    Jacked up, the wheel spins nicely and the wheel bearing is good. Four year old rear KYB shocks, rear driver side riding 3/8in lower. There's one really good gouge in the lip of the rim. Is it shocks? Could a bent rim make this wear pattern?
  2. JC91006
    16,936
    8,647
    Maybe you just need the tires to be balanced?
  3. Gen2Prii
    24
    South Florida
    I thought that a possibility, however the weights are still on the rim from when the tire was installed a couple months ago.
    The last tire I had on this hub lost the weights at some point and had random bald spots, but the tire wear was different than this time. This time is cupping, I believe.
  4. JC91006
    16,936
    8,647
    If you have cupping on the tires, it's worn/leaking shocks. Since 1 side is sitting lower than the other side, I would think you have a blown shock on one side.
    Luckily rear shocks are fairly cheap. Preferably replace everything in pairs, a pair of shocks and a pair of tires
  5. Gen2Prii
    24
    South Florida
    Thank you, that's the confirmation I needed
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    That picture shows a tire with a "shifted belt"- part of the tread is separating and makes a lump that sticks out. (see how the tread has a "peak" towards the left side?)
    So that tire is no longer round, it's eccentric which gives you that "wub-wub" shaking. The tire is bad and needs to be replaced - asap.
    #6 mr_guy_mann, May 31, 2022
  7. Longinus876
    Longinus876 Member
    105
    Long Island
    Bent rim. What did it turn out to be???
