Welcome to Winter (Solstice)
Discussion in 'Environmental Discussion' started by bwilson4web, Dec 22, 2025.
  1. fuzzy1
    10,691
    "different electrical resistivity" does not equate to being a battery. And that link makes no mention of any battery.
  2. fuzzy1
    10,691
    It would probably be more useful to compare capacity ratings. Mine is rate 7.0 kW DC, 6.0 kW AC. But I am one of the few who give AC capacity, most just list the DC figure.
    For those who must know, my PV modules cover 26 x 1.677 m^2, or 43.6 square meters, not counting the inter-module gaps (1" wide clamps in original field, 0.5" in second field).
    I would like to add another 2 to 3 kW-DC, but other activities interfered this year, and the increased frailties of age might keep keep me from ever doing such roof work again.
    Today's modules are both larger and higher efficiency than what I have.
  3. Mendel Leisk
    42,310
    For sure. If you're at the North (or South) pole at summer soltice, it must be strange as heck: the sun's a particular angle up from the horizon (~23 degrees), and stays at that angle, tracing a circle all the way 'round, in the course of 24 hours.
    52,807
    right now, there's more than an hours extra light in orlando compared to boston
    on june 21st, we get an extra hour and a half in the morning, but who cares, farmers?
    #24 bisco, Dec 23, 2025
  5. ETC(SS)
    7,523
    Every US state is represented by a VERY tiny number of people who thought that Seinfeld was mindless drivel.
    Since I am a proud delegate of Indiana's portion of that minority I had to look up some of the details of this Festivus holiday, since I had no other frame of reference.
    AND.....I'm glad I did!!!
    I'm SO looking forward to @Mendel Leisk Airing of Grievances and the Feat of Strength......
    DONT MAKE US MAKE A THREAD! :)
  6. Mendel Leisk
    42,310
    Well, grievances...:
    Our daughter alerted me to this phenomena, because she'd bought the pipe, and could I make a base. I made a nice, sturdy one I thought, a big improvement on the pictured original.
    I thought wrong, had to dumb it down, make another, faithful to the obviously inferior one.
    Don't walk away, there's more....
  7. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Must be aluminum.
  8. hill
    9,022
    If you Market it, they will come
    VelvetFoot likes this.
  9. ChapmanF
    18,995
    That's some extra-heavy irony right there.
  10. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    Oh, the sacrilege:
  11. Mendel Leisk
    42,310
    Ours was a solid aluminum pole.
  12. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    Did you keep it in the crawl space?
  13. Mendel Leisk
    42,310
    It's our daughter's. I doubt she has a clue where it is now, a few years later.
  14. ETC(SS)
    7,523
    Just gonna get some popcorn....
  15. fuzzy1
    10,691
    Yes. This seasonal daylight change from the tilt of the poles has zero impact at the equator, increasing at the poles from zero daylight in winter, to 24 hours in summer. At my latitude, daylight varies from about 8 hours at the winter solstice to 16 hours at summer solstice.
    Checking up and refreshing on other things things, there is a different change at and close to the equator. Because of Earth's orbit being elliptical instead of perfectly circular, the length of the solar day varies around the year, but by less than +/- 30 seconds. At the equator, both day and night are equally longest about December 23, and shortest about September 16. This effect covers the whole planet, but is overwhelmingly swamped by the tilted polar axis once you get any distance from the equator.
  16. tochatihu
    tochatihu Senior Member
    9,963
    3,846
    Kunming Yunnan China
    2001 Prius
    As a holiday gift to PriusChat, I address a question: where on Earth has the most hours of daylight - when Sun is visible above horizon. I used website
    Timeanddate.com
    Doing this. I am among those accepting idea that Earth is nearly spherical and orbits Sun with an inclination of about 23.5 degrees. Things come from that. Different latitudes on Earth ‘see’ Sun above horizon for different total hrs in a year. Before disclosing, I ask readers to say/claim/guess what latitudes see the most light. Please do not scroll down before staking your claims.
    Having examined latitudes in 10 degree bands, the most lit is 80 degrees (N or S). More accurately it is may be above or (probably) below 80 degrees, but I have not looked closer. It is certainly poleward from Arctic/Antarctic circles at 66.5 degrees latitude. PriusChat readers might have occasion to win bar bets on this. Other bettors may suppose that equatorial or polar sites get the most light. Take their money and send none of it to me. To win you might need to do actual work extracting and processing data from timeanddate.com
    Giod.
  17. fuzzy1
    10,691
    ^ Cheating by searching online, I'm finding several conflicting answers, citing different factors that I'm not sure others considered. Will have to explore this later.
    People exploring this should remember the definition of sunrise and sunset, which is when the top edge of the sun, not its center, is visible on the horizon. The sun is not a point source, but has a real angular diameter. And near the horizon, atmospheric refraction causes the sun to appear higher than it really is (or would appear if the atmosphere vanished). This amount is variable depending on weather, but almanacs just picked a standardized value. Because of these effects, annual daytime exceeds annual nighttime by many hours.
    P.S. The Earth's orbit around the sun is not circular, but slightly elliptical, so the Northern and Southern hemispheres must be treated separately.
    #37 fuzzy1, Dec 23, 2025
  18. tochatihu
    9,963
    3,846
    2001 Prius
    Solar edge visible above horizon is why equator sites get about 12.1 hrs of sunshine daily throughout year.
    Totaling 4423.5 hrs/yr. But bested at 80 o latitude with 4627 hrs/yr.That's the fun of it - 200 hrs more.
    I can 'explain my work on this in detail if anyone really wants to know.
    Have not come up with an explain that 'squares' with flat-earth hypothesis.
  19. bwilson4web
    16,523
    I don't have the exact area. This is what I know:
    • 16 - 400 W panels ~= 6.4 kW peak measured 4.8 kW peak
      • 4 - groups with micro inverters
    • 30 degree roof pitch, southwest south facing roof at 34.8 degrees N latitude
      • 48.8 degree minimum solar angle at noon to 78.2 degrees maximum in summer
        • 83.6 degrees (-6.4 degrees below vertical) - lowest, noon offset from vertical in winter (34.8 + 48.8)
        • 108.2 degrees (18.2 degrees over vertical) - highest, noon offset in summer
    • 13.6 kWh solar roof battery, 86% efficiency IN-OUT
    My challenge in the first year has been moving loads to optimize direct solar power to where it does the most good:
    • 7.4 kWh EV charging - maximum 30-32 A
      • Reduced to 16 A, 3.8 kW, to stay below peak solar output and minimize grid power purchases
    • Washing and drying - moved to after sun rise and stop at sun set
      • cold water soaps
      • hybrid clothes dryer
    • Shower and dish washing - after sun rise for the <400 W, hybrid hot water heater
    • Range and oven cooking during daylight hours and fridge snacks when dark
      • small quantity reheats to edible temps (i.e., coffee, tea, snacks)
    So far since May when the solar roof went online:
    • 5,326.6 kWh (~54%) - solar production, not charge $0.12/kWh
    • 4,629.7 kWh (~46%) - grid import (purchased at ~$0.12/kWh)
      • 352.5 kWh - grid export (excess solar, free, back to utility)
    With better, automated, whole house load management, I should reduce the grid purchases and maximize solar power usage.
  20. ETC(SS)
    7,523
    See the most light or see light the most?
    Local horizon at sea level or the reference ellipsoid or the local horizon?
    Does daylight include light from the sun during one of the twilights (nautical, civil, astronomical) or 'directly lit?"
    If we presume a local horizon and 'directly lit' then the answer is probably in the southern hemisphere which in 'lit' latitudes is a little bumpier.
    (Edit after reading further...)
    Well....according to the Googles I was wrong.
    I was thinking that since the Earth bulges in the middle by more than 20 miles that there would be some obscure Chilean mountain top that was more illuminated (illuminated more?) by the nearest star in the 'lit' latitudes....
    The Googles say that my geography is a little off.
    Ecuador’s Mount Chimborazo is the 'sticky-outtiest' place on the planet......
    I guess THAT is why they call it Ecuador.
    However (comma!!!) our inclination makes the light math 'lean' the otha way.
    The Googles list Mount Forel, Greenland, as the most lit place on earth.
    Or...is it the place that's lit the most?
    It's located around 66.93° N latitude and 11,099 ft above mean sea level.
    For math nerds that's about 11250 feet HAE.
    #40 ETC(SS), Dec 24, 2025
