Western Washington pruis experts needed.
Discussion in 'Gen 2 Prius Main Forum' started by BUCKed, Oct 4, 2023.
  1. BUCKed
    BUCKed Junior Member
    23
    I am needing help with my heating system. I have tried everything I know how and really just need an expert to help me if possible. I am in western Washington around the olympia area. Able to travel a bit for the right help!
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,521
    Durham NC
    Heating system or cooling system give a brief description of the basics you select the temperature from the center display console put on the fan manually I generally put it on high so I have a fan blowing the temperature set on HI I feel the fan blowing as the car warms up I do get heat or it stays cold forever and I have a bunch of clicking and no fan? It is not really a hybrid specific problem anybody that can work on air conditioning and heating systems in a car is not going to be completely baffled by the Prius. Many cars from 2005 on up have climate control computers that control the fans the compressor and what have you. Because you have an electric compressor in the Prius doesn't really make a difference that just means you don't have a belt and it's not engine driven It has a motor in the compressor that does the pumping instead of a belt on a clutch
  3. fuzzy1
    10,720
    SFO likes this.
  4. Stevewoods
    Stevewoods Senior Member
    667
    1,273
    where I am
    Autoworks of Port Townsend alwways did right for me and fam.
  5. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    I'm in Olympia area... I just private messaged you!
