Wet headlights
Discussion in 'Gen 3 Prius Main Forum' started by Frontporch, Sep 10, 2025.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    This is now #1 in the archive!!!
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  3. ASRDogman
    ASRDogman Senior Member
    8,057
    4,085
    Just know that there are people here that hate the 3rd generation and always bash it and
    the people who like it and don't have the issues they cry about.
    EVENTUALLY, you will need a head gasket. But it's nothing to lose sleep over.
    I went 301,000 miles before mine started failing. I had ordered the parts I needed and was planning
    on replacing it within a week or two BEFORE it failed, You can do the same.
    The oil burning is another issue. I'm at around 1.5-2 qts every 5000 miles. Depending on how
    Fast and hard I drive it.
    From what I saw here in Prius Chat, the ones that failed earlier were the ones that did mostly
    city driving. 90% of my driving was highway.
    I'm still on the original master cylinder and booster. But it's cycling at around 21 seconds. It was
    around 30 second 8 years ago when I first got the car.
    I'm planning on replacing the engine with a remanufactured one and do the brakes at the same time
    so that I will have more room.
    I REALLY like my Prius! I has been very reliable and faithful. And 2 weeks ago I installed the finished Sodium hybrid battery, and it's GREAT!
    Be happy with your Pius, no matter what the cry babies cry. EVERY car will need parts and work, parts
    wear out.
    Make sure you got the correct bulbs for the head lamp assembly. I can't find them for the correct bulbs
    mine has. I would have to buy an adapter wire harness if I replace the assemblies.
    So I'll just polish them, eventually....
    Frontporch likes this.
  4. ETC(SS)
    7,534
    :mad:
  5. Brian1954
    Brian1954 Senior Member
    2,671
    1,069
    South Central PA, USA
    My post is off topic.
    I know that you are referring to the NexPower battery, but what do you mean by "finished" Sodium hybrid battery? What is "finished" about it?
    Why did you replace the NexPower sodium-ion hybrid battery that you installed last year?
    #25 Brian1954, Sep 14, 2025
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,078
    6,939
    Texas Hill Country
    This is a good strategy. Gasketmasters has been making a good living for years on gen3 head gaskets and engine replacements as have many other independents nationwide. In fact Gasketmasters put out a video last year recommending preemptive hg repairs.
    Toyota issued a tsb recommending the latest ecm software as a preemptive hg measure.
    So when some of us are warning about head gaskets, it is for a reason. We are not gen3 haters; we are realists.
    Because they did not get it right the first time.
    "You can fool some of the people all of the time, and all of the people some of the time, but you can not fool all of the people all of the time."
    Famous Republican President who was world class woke
  7. Frontporch
    Frontporch Active Member
    549
    128
    Nj
    Do you have the halogen bulbs?
  8. ASRDogman
    8,057
    4,085
    I have the 9005 and H11 bulbs.
    I've looked at dozens of assemblies. And they either say they are for different bulbs, or when
    I write and ask none of them have said they are for the ones I have.
    So I would have to buy new bulbs, and 2 wire harnesses to adapt the original harness to
    the other type of bulbs.
    I rarely drive at night so it's not a huge deal, I've just not been motivated to clean them properly.
    Eventually I will though.
  9. Dave1UK
    Dave1UK Junior Member
    87
    London, UK
    Active
    My headlights have yellowed a bit/oxidised will be taking them out and restoring, as well as fixing same issue as yours but just 1 of mine not both got condensation or a leak.
    If you check this video out on how to test for a possible leak/can use his box and heat gun method to dry the headlight out properly.
    You will need to remove the front bumper though to gain access for removal.
  10. rrg1234
    rrg1234 Junior Member
    New Jersey
    If you want to go cheap to fix it. 10 years I had water showing up in the lens.
    I got some good electrical tape and wrapped the seam a few times after removing the lens out of the car.
    It’s been clear all this time in the east coast.
  11. hurricos
    hurricos Junior Member
    74
    24
    Burlington, Vermont
    > I came here with headlight issues and now I need a head gasket?
    This would be less funny if it weren't true. I love me a Gen3 :^)
