Wet key
Discussion in 'Prius c Main Forum' started by scudmonster, May 8, 2012.
  1. scudmonster
    scudmonster New Member
    31
    Arkansas
    So, one of my "keys" for the C4 was in the pocket of my husband's jeans and went through the wash tonight. We haven't tried it to see if it works yet, worried that if we do we might short it out or something. Any advice would be greatly appreciated!
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Ive seen a lot of RKE go through the wash i think youll be ok. Those things are pretty tight
  3. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Open the fob per the instructions for changing the battery in the manual. Remove the battery and the circuit board and let them air dry overnight! Maybe have a fan blow on them. Reassemble tomorrow and cross your fingers! Good luck!
  4. camire
    camire New Member
    Lowell, MA
    This happened to me once before. While it may seem like a big problem at first, there are a few simple steps you can take to ensure your new fuel-sipping Prius C is not damaged.
    1. Acquire a soft, absorbent (preferably 100 percent cotton) piece of fabric.
    2. Take the key and gently rub it against the fabric so that the moisture from the key is transferred to the fabric. Do this for several minutes until the key is dry.
    3. Acquire a blow dryer.
    4. Take the blow dryer and aim it at the key. Turn the blow dryer on the "cool" setting so as to not melt the key.
    5. Shuffle the key in your hand as the air from the blow dryer hits it in order to make sure all moisture evaporates. Make sure not to miss any crevices in the key. This is where dew loves to hide.
    That's about it. You should be all set at this point. Feel free to insert your key in the Prius C ignition. Good luck, and make sure to report back on how it went.
  5. scudmonster
    31
    Arkansas
    Thanks for the responses. Just to be clear, this is the keyless fob (is that the correct term?) that got wet. Is your advice still the same?
  6. scudmonster
    31
    Arkansas
    More info...my husband just told me that the key also went through about twenty minutes of a high heat dryer!
  7. Erikon
    819
    105
    Rochester, NY
    Just opened my fob and the electronics are protected by a rubber type cover, so it should be fine. Take it apart anyway just to be sure that it's dry, heat probably hasn't hurt it unless the outside is melted!
  8. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Still shouldn't change the recommendations on drying overnight with the battery removed.
    You want to make sure you don't go near the car until you are sure it has dried completely, because the fob electronics will engage when it gets close enough to the car.
    Since you should have another fob available, I'd just use that one for a e couple of days until the other one dries out. You may want to reinstall the battery with the cover off just in case having the battery out "de-programs" the fob. I don't think this will happen, so I am just being cautious with my advice. :)
    iPad
  9. Erikon
    819
    105
    Rochester, NY
    Agreed, what dealers charge for a replacement fob will give you a heart attack!:eek: let it sit and air just to be safe!
  10. scudmonster
    31
    Arkansas
    Just opened the fob. Everything looks completely dry. Should I still remove the battery?
  11. Erikon
    819
    105
    Rochester, NY
    Sure, the fob doesn't need power to retain its programming. Lay out the parts in a safe area away from pets and kids for the night.
  12. N1XRR
    N1XRR Junior Member
    33
    Lavonia, GA
    I've worked in the electronics industry for years (where, among many other things, I repaired circuit boards). The goal is not just to dry the electronics, but dry them "quickly". Simply taking it apart and leaving it out doesn't dry it completely unless you leave it for a week or so (and will lead to corrosion in the process). The rubber people are seeing is the switch membrane, it does not protect the electronics.
    1) Take the key-fob apart, remove battery
    2) Place entire disassembled key-fob into a container with a lid, cover with fresh, dry rice
    3) Put lit on container, let sit 24 hours
    4) Reassemble
    The rice will absorb any liquid or gaseous water that is in the electronics/buttons. This is how the professionals do it.
  13. Erikon
    819
    105
    Rochester, NY
    Did the key work?
  14. ewaboy
    ewaboy Active Member
    693
    205
    Hawaii
    Edited to add - Sorry - didn't see the earlier post by N1XRR re: rice.
    Don't know if this is applicable. One trick that people use to dry out cell phones that get dunked - usually in toilets:embarassed::p - is to stick the phone in a bottle or container and fill the container up with raw, uncooked rice. Claim is that the rice draws out and absorbs the moisture. Don't eat the rice afterward....:D I think it's recommended to remove the battery.
    Saving a Wet Cell Phone with Rice: Does it Work? - KFVS12 News & Weather Cape Girardeau, Carbondale, Poplar Bluff
    YMMV
  15. scudmonster
    31
    Arkansas
    Thanks to everyone for your help....THE KEY FOB WORKS!!!!! (sigh of relief)
  16. Erikon
    819
    105
    Rochester, NY
    Whew! At least it's clean!:p
  17. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Glad to hear you saved it. :)
    Anyone know how much a fob for the c costs?
  18. N1XRR
    N1XRR Junior Member
    33
    Lavonia, GA
    Good news!
  19. Erikon
    819
    105
    Rochester, NY
    Dealers charge $350 for the fob, another hundred to program it, but it varies depending on the dealer. Some will really try to ream you and others cut you some slack for customer relations.
  20. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Whoa! :eek:
