Wet Rear and now front passenger side floors.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ana Hernandez, Jun 1, 2017.
  1. Ana Hernandez
    Ana Hernandez Junior Member
    61
    New York City
    Hello,
    I'd like to know where this water is coming from before I start messing with it, I've heard AC Hose clogged. But why is the rear seat more wet.
    Thank you anyone with info regarding this issue it will be greatly appreciated.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    check your door seals
    52,863
    we've seen everything from rain gutters to rear window washer broken tubing. check the 12v battery and spare tire area as well.
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    It's usually either the A/C drain hose or, if equipped, the sunroof drain hose. Especially if parked outside where there are trees.
  5. Ana Hernandez
    61
    New York City
    Hey, yes that rear compartment on the trunk has always gotten filled with water, I just removed the little plug and rain the water straight out. But what does that have to do with the wet floor? That use to happens wayy before the wet floor.
  6. Ana Hernandez
    61
    New York City
    I tried finding that hose, I unassemble the flooring and got all the way to the metal, there are about 3 layers of material, foam etc. That were soaked to the max with water, I saw a hose poking to the outside of the car but connected to nothing on the outside, it was just facing out of the car. I couldn't find anything else that would let me see where the water was coming from. (On the front passenger seat).
  7. Ana Hernandez
    61
    New York City
    I will check that today! :/ because after all my AC Is Working good, and the wet floor is wet regardless of when I turn on or leave off the AC.
    It Mightttt be getting flooded when it rains, not sure.
