What’s her value?
Discussion in 'Prius Cars For Sale' started by liberate88, Jul 30, 2022.
  1. liberate88
    liberate88 New Member
    23
    Idaho
    Im ready to part with my 2007 Prius with 220,000 miles. Her hybrid battery is up for repair. The diagnostic showed it was #12 that wasn’t holding a good charge. The battery fan is also blowing really loudly. I tried to fix it by cleaning the corrosion on the plug and it did help for a little bit but I know I didn’t do a very thorough job so it could be just that. The whole rear well area has quite a bit of rust because of the leaking hatch so I know there’s probably other corrosion besides that one plug and for example there’s rust underneath the 12 V battery. She has two dents in the front bumper,one on each side, (not by me, that was previous owners). And the interior is just a bit worn and discolored and things like that.
    What she has going for her is that last year I had the inverter water pump replaced. And just before the battery issues came up I put new tires on her last minute and they’re pretty nice $800 45,000 mile tires that I think only drove 1000 maybe 1500 miles. I had it thoroughly checked out in may and said everything mechanically looked good except the timing cover is allowing a slow leak, and the front end doesn’t offer the smoothest ride.
    I was hoping for $1,800, thoughts?
  2. JC91006
    16,482
    8,400
    I think $1800 is a reasonable price to ask. You'd be surprise how many people would want it at that price.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,974
    4,716
    Texas Hill Country
    I might try to judge the price if it had a "refurb" $800 battery. If it was then worth $4500 it would be worth the upgrade.
    #3 rjparker, Jul 30, 2022
  4. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    I might be able to find someone in Western Washington to buy this and we could come out with a replacement battery pack to drive it home. You'd deal direct with the buyer, I'd just assist. How many hours from the main highway in Eastern Washington is your location?
  5. liberate88
    23
    Idaho
    we have thought about this, though I live in a small town and closest city is an hour and a half drive on the highway. And would it be just $800? I thought refurbs cost more than that, plus the labor fees.
    #5 liberate88, Jul 31, 2022
  6. liberate88
    23
    Idaho
    There’s a couple of freeways in eastern Washington, but we are 6.5 hours from Kennewick in southeastern WA near the 82
  7. rjparker
    7,974
    4,716
    Texas Hill Country
    Refurbs are just mix and matched used cells in an old battery assembly. A get you by for a while solution. The supplier takes your battery and changes out a few cells for the next guy. You need to let your fingers do the walking and call around.
    The actual swap is usually less than an hour. I guarantee anyone who buys it from you will flip it using this solution and make $2k or more even considering their time.
    #7 rjparker, Jul 31, 2022
