What’s making this noise?
Discussion in 'Gen 3 Prius Main Forum' started by samposey, May 27, 2026.
  1. samposey
    samposey New Member
    Montana
    I’ve got a 2015 Prius. Recently, it has started making a whining noise every 15 seconds or so beginning when I unlock the vehicle, throughout my drive, and after I shut the vehicle down and lock it. It takes a bit after shutting down for the sound to go away. I was able to see what is causing the sound, just have no idea what it is. Can anyone help with solving my problem? I’d love to fix it on my own without taking to the dealer, if possible. I’ve attached a video below that shows the sounds and is zoomed in to the part making the sound.
    #1 samposey, May 27, 2026
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,432
    Pacific Northwest, USA
    Google is requiring a login screen to see what you posted and I'm already logged into my Google account.... To protect Priuschat from spammers we require new user to be moderated for their first 5 comments or posts. Once you get past that you'll be able to post links & stuff.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    "I was able to see what is causing the sound, just have no idea what it is."
    Okay, then WHAT is it? And since you can "see" it, you can likely fix it?
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,108
    6,970
    Texas Hill Country
    Describe the location.
    If its under the hood, back drivers side its probably your brake booster assembly going bad. Fairly expensive and somewhat difficult diy. A good installed dealer price is around $2500 due to a $850 part and lots of labor and use of Techstream to flush and calibrate
    However when it fails you will gets several warning lights, codes and perhaps weak brakes.
    samposey likes this.
  5. samposey
    samposey New Member
    Montana
    I appreciate you communicating I need to be monitored. Definitely don’t want to be spamming anyone.
  6. samposey
    samposey New Member
    Montana
    Sorry, I should have described the location. It is on the drivers side under the coolant and brake fluid reservoirs.
  7. samposey
    samposey New Member
    Montana
    This is why I was asking the question. I don’t know what it is. I was hoping those more experienced than I would be able to help me identify the issue.
  8. ASRDogman
    8,066
    4,089
    That's why the booster and pump are. More of a whirling sound, right?
    "If" that IS the issue, you'll need someone who has worked with that before to do it.
    Dealership or independent shop with Prius experience.
  9. ChapmanF
    19,025
    The thing the brake pressure pump sounds most like to me is a joy buzzer. Or maybe a rattlesnake. Kicks on, whirrs for a couple seconds, and stops. Sometimes you notice it has a pitch, and the pitch drops a little between when it kicks on and when it stops. Like the joy buzzer spring winding down.
    Does that sound like what you're hearing?
  10. Prius_Gnome
    Prius_Gnome Member
    111
    39
    Long Island, NY
    It's hard to diagnose without being able to hear the actual sound.
    Just to put in my 2 cents, perhaps it's your coolant control valve. However, a problem with that part usually throws a P1121 code.
  11. Brian1954
    Brian1954 Senior Member
    2,687
    1,073
    South Central PA, USA
    A Gen 3 does not have a coolant control valve. The Gen 2 has the valve.
  12. ChapmanF
    19,025
    Right, you don't really have to know what the thing really is, but if you're going to tell us "I was able to see what was making the sound", then if you're not going to let on what you did see making the sound—some thingy under the brake and village reservoirs—how is that not just teasing us?
