What’s that sound?
Discussion in 'Prius c Technical Discussion' started by Humanz, Nov 4, 2017.
  1. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    My car has 67k miles on it. And I’ve recently been hearing a noise coming from the back of my car, right beneath the backseat. It’s almost like a cracking/popping sound. Kind of like Rice Krispies or Pop Rocks candy. I’m worried there’s something possibly wrong with the battery, maybe?
    I also hear it when I’m riding beside other cars. Anyone else hear anything like I described above? Any advice on how to stop it?
    Thanks in advance.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    WilDavis likes this.
    52,773
    when you're riding beside other cars, with the window down, like it's outside? how is it different than when you're not riding beside other cars?
  4. xliderider
    8,140
    3,277
    Honolulu, HI
    Does the sound change with speed, or does it remain constant.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Pebbles or small stones stuck in tread in off-side hind tyre?
    Raytheeagle likes this.
  6. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    That sound maybe coming from anywhere. I would suggest getting someone in the back seat while you're tooling down the road to try to pinpoint it
  7. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    The sound increases with speed. It sounds almost like a torque wrench.
  8. bisco
    52,773
    could be a pebble, cvj, wheel bearing, bad tire, and etc.
    ztanos, WilDavis and Raytheeagle like this.
  9. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    Welp...that narrows it down lol I told an advisor at Toyota about the issue and he said it was normal...which I'm certain isn't.
    Hopefully its nothing major, and can be fixed somewhere else because it hasn't effected the car in any way so far.
  10. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    Going to try that soon.
  11. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    That would cause the sound to be heard in the car as well?
  12. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    I managed to record it, if anyone cares to hear it.
  13. WilDavis
    2,493
    2,155
    49
    I hear the sound of the tyre tread. Are you certain there's no small stone-chips stuck in the tread? How knobbly are your tyres? They sound quite knobbly (at least compared to those on mine!):unsure:
  14. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    My tires in the front are about a 7-8 on tread. The back are terrible, I know that much. I can check for stones and whatnot in the morning. You didn't hear the other sound? It's pretty consistent at the :53 mark until I hit the back at 1:15
  15. bisco
    52,773
    you can do the pebble in the tire check yourself. eliminate that before paying someone, or have a local mech put it on a lift and spin the tyres.
    Humanz and Raytheeagle like this.
  16. Humanz
    Humanz New Member
    Los Angeles
    2015 Prius c
    So I was told that it's the catalytic converter by one shop, then I went to another and they said it wasn't. If thats the case, would I even be able to drive it the way that I do? The performance isn't effected at all from what I can tell.
  17. bisco
    52,773
    no idea, but i've never heard of a cc making noise. i suppose anything is possible, but unlikely on a car that new.
  18. Gasoholic
    Gasoholic Junior Member
    35
    Bakersfield, Ca
    2016 Prius c
    I cant hear a thing but road noise.
