What About Halogen Headlight Bulbs
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Smooth Operator, Aug 5, 2005.
  1. Smooth Operator
    172
    Cowichan Bay, BC Canada
    I read the discussion about HIR bulbs for the fog lights. I was all prepared to put these in my headlights. Then I realized that they are not available for our 9003 style headlights.
    I'll be doing a dark morning/dark night 50 km commute on a winding road starting in a few months. I want ot make sure I can see where I am going.
    I understand as well that there foggy periods, so I am trying to track down a Canadian source for HIR bulbs for the fog lights.
    So what is the best replacement headlight bulb to provide good light?
    I'm thinking maybe the Sylvania SuperStar.
  2. Tideland Prius
    16,155
    That's probably the most recommended.
  3. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Remember that 9003 is also known as H4
  4. Areometer
    Areometer Silver Business Sponsor
    578
    Tyngsboro, MA
    If you want the brightest output, go for IPF Fatboy H4. They are much bigger than regular H4 and they consume 80/60w (L/H), instead of stock's 55/65w.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I run SilverStar's in both my wifes and my Prius and they work good and are legal. The fog's are Pi** useless at best. I'm thinking there has to be a replacement light assy that will fit in the location of the stock fogs and provide some useable light in the winter fogs that we have here. If I find any thing I'll let you know.
  6. silentak1
    893
    28
    LA
    Another note, i wouldn't recommend buying a headlight bulb with actual current draw of over 65/55w (high/low beam) because it may burn your harness!
    I've seen it happen many many times... it's not costly to replace them ($30-60), but time comsuming.
  7. Areometer
    578
    Tyngsboro, MA
    Right, thanks for the warning. That's why for maximum safety, one should also use the heavy duty wire harness.
