What accounts for this?
Discussion in 'Gen 2 Prius Fuel Economy' started by hobba, Jun 20, 2009.
  1. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    I'm guessing this is precisely your problem. Different pumps. Some will knock off 1.5 gallons before the amount I KNOW I have used, others just shy. Did the MFD MPG say something close to 46 and 30 respectively? Before you pump, calculate how much you SHOULD have used. If the pump kicks off before that, keep going. You aren't topping off, just accounting for a bad pump. My bet is you got ~37 there and 37 back but the pump in Orlando shut off early, so you got more in on the fill back at home than the actual miles and MPG would dictate.
    How far is it to Orlando and what sort of roads? Are you driving with 'elasticity' meaning leaving enough space between you and the car in front that you rarely slow down even though those in front of you are continually jumping from accelerator to brake pedal? 37 MPG would just kill me except in the depths of Vermont winter (OK it still kills me but it is at least explainable).
    Plus there is the 'out and back' issue. Not much for mountains in Florida but if you happened to have a 20 MPH tail wind on the way to Orlando it is a 20 MPH head wind on the return. BIG delta in MPG, not 16 MPG delta but it can easily be 5 MPG each leg adding up to 10.
