What are my choices when Remote Connect expires after 1 year?
Discussion in 'Gen 5 Prius Main Forum' started by PaigeMiller, Dec 28, 2023.
  1. thnok
    thnok Member
    122
    44
    2023 Prius
    It's only on Prime lineup and even then higher trims.
  2. rpT
    rpT Member
    39
    31
    new york
    2023 Prius
    Limited AWD-e
    damn. i have a fully loaded prius limited but not prime 2023. Wth toyota!!!
  3. MrLightRail
    MrLightRail Junior Member
    26
    Oklahoma
    In my settings on my LE, I can enable or disable "parking assist", but I don't see a button to use it. How does this work?
  4. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    Parking assist are the sensors that beep when you are parking your car.
    Also for others, TJA is likely on the base model prime in Canada. You don't get a year free of drive connect trial with it, so you can't use it. But it has an on/off toggle in the settings of the car itself.
    So I guess if I wanted to I could pay the $20 or whatever it is for 1 month to see if it does in fact work. But I'd probably wait until after the winter because I don't want to test it in winter roads covered in salt which are all white even when dry lol
  5. pgb205
    pgb205 New Member
    earth
    Ok so remote start requires 15/month fee for cellular network usage. Is there a way for a driver to get in on that somehow from the car? Meaning can I use the cellular as hotspot on my laptop?
  6. I Throw 99
    I Throw 99 Junior Member
    28
    2023 Prius
    XLE AWD-e
    Yes... if you pay for it. It is called wifi connect, and cost an extra $25 a month. My car came with a free month of hotspot access. I never used it, and let it expire.
  7. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    As stated above, there is Wi-Fi Connect which is $25/month and specifically for turning the car into a mobile hotspot. The big problem is that Wi-Fi Connect needs to be added onto one of the other plans. So it's really $40/month or $50/month(depending on which base plan is paired with it).
    Base Plans:
    $15/month - Music Lover - Remote Connect + Integrated Streaming (Apple Music and Amazon Music)
    $15/month - Go Anywhere - Remote Connect + Drive Connect(cloud-based nav)
    $25/month - Premium - Remote Connect + Integrated Streaming + Drive Connect
    Add-On Plan
    $25/month - Wi-Fi Connect - turns the car into an internet connected hotspot (via AT&T wireless)
    Connected Services Plans
    PhoS likes this.
