What are the consequences of driving with a bad ABS brake actuator?
Discussion in 'Gen 2 Prius Main Forum' started by flippo, Jan 12, 2018.
  1. Soybeanmike
    Soybeanmike Junior Member
    Connecticut
    Four Touring
    Hi everybody- what is the expected life of a brake actuator?
    51,835
    200,000 miles
    51,835
    there's a new warranty, check with your dealer, i think you're good.
  4. Jude23
    Jude23 New Member
    Ghana
    Mine motor is burnt now. i want to know where i can get one to buy. i want the accumulator and motor together. can you please recommend a dealer for me as soon as possible
  5. ChapmanF
    18,056
    Um ... yikes. I don't know anything about dealers in Ghana. Are there many Prius c's there? Enough to have them in salvage yards? The new price at a dealer is fairly steep (at least in the US); salvage pricing may be more attractive.
  6. Hockstedler
    Hockstedler Junior Member
    MA
    Renee what was the resulting communication back to you for the complaint you filed. I may want to do the same thing as my 2005 with 244K on it has been making the noise associated with the Actuator Failure. NO lights yet just the noise of the pump running on and off al the time until I turn the vehicle off and the computer goes to sleep then the noise stops.
  7. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Your car is too old and won’t be covered. Your on your own for a replacement.
    Dxta likes this.
  8. Cerebrain111
    Cerebrain111 New Member
    Joliet Illinois
    Guess what toyota is asking for a part number that they want to sell a high price, but I discover that I can see the part number just by locating the actuator and you can find it anywhere for around 200 dollars
  9. dolj
    dolj Senior Member
    8,423
    4,284
    Wellington, New Zealand
    Guess what? Toyota is selling you a NEW part. Your $200 part is a second-hand part. It may work, or it may be just as broken as the one you are trying to fix.
    Horses for courses.
  10. Bad Uncle
    Bad Uncle Junior Member
    china
    I bought a second-hand actuator. After a day's work, everything was normal,
    kenoarto likes this.
  11. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Is yours making the buzzing (constant beep) yet ?
    that’s the sign for stop driving. I’ve dealt with a ton of these.
    Once the buzzer starts (or cud be even before) the brakes will give out. In other words they will cease to function (randomly usually)
    so you will be cruising and hit the brakes and it will make usually no effort and then you get a hard thud usually. And if ur lucky it might stop just enuff. But driving u will be guaranteed to be in an accident.
  12. cherry albrecht
    cherry albrecht New Member
    Hawaii
    Can you link me to this new warranty? How long is it active for?? My actuator needs replacement 03/05/2020
  13. bisco
    51,835
    toyota.com/owners, plug in your vin for recalls, tsb's and extended warranties
  14. Teresa Y Kirkpatrick
    Huntsville, AL
    They should set a 150,000 guaranty on this part, not a date- because not everyone drives as many miles as others. If they know it id faulty- if it happens before 150,000 miles it is their defective part, it would seem. It would be different if this problem were not so common. I would love to know the statistic of how many have gone bad prior to 150,000 miles. Toyota is hurting themselves with reports like this...
  15. JC91006
    16,761
    8,562
    This probably will fail with every car eventually. Toyota was kind enough to extend the warranty on it, other companies usually don't offer this type of service.
