What Brand of Battery do you like ? (Auxiliary)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jul 14, 2022.
  1. PriusCamper
    PriusCamper Senior Member
    12,774
    5,175
    Pacific Northwest, USA
    You use slightly longer bolts than what it comes with and slightly larger washers than each of the terminals and think club sandwich with washers being the bread, terminals being the meat and the bolt being the toothpick that hold the sandwich together.
    Also this battery is a tiny bit taller than OEM so you have to slightly modify/remove either the base the battery sits on or the cover that goes on top:
  2. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Seems like I would have to remove the connectors at the end of the cable to reduce thickness right? Thanks
  3. Taxi/Limo
    524
    107
    What are the dimensions of this ebay won't tell me
  4. PriusCamper
    12,774
    5,175
    That info is further down on that page...
    It says: 9.00" x 5.40" x 8.43" (LxWxH)
    Taxi/Limo likes this.
  5. Taxi/Limo
    524
    107
    Thanks for the help PriusCamper
  6. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Keep in mind that the OEM battery has a 7-year prorated warranty, plus free towing in the event of a battery failure. And few of the aftermarket batteries have a connection for the Prius's vent tube.
  7. Taxi/Limo
    524
    107
    What is the purpose of a vent tube?
  8. bisco
    51,961
    lead acid batteries off gas. if not outside the car, than inside
  9. Mendel Leisk
    41,473
    The off-gas is hydrogen.
  10. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    AGM batteries normally recombine the hydrogen and oxygen. Significant off-gassing happens only if something has gone badly wrong, for example a cell shorted internally and others being grossly overcharged as a result.
  11. NewHybridOwner
    607
    283
    W. Michigan
    But the OEM battery does have the vent that connects to the vent tube, so that any gases generated are conducted away from the passenger area.
  12. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    So does my $65 non-OEM AGM battery after I added that capability, which wasn't difficult. It's 7½ years old now, and still performing its duties.
    douglasjre likes this.
  13. Mendel Leisk
    41,473
    Curious how did you do that, drilled a hole?
    CR94 likes this.
  14. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Yes, among other steps.
    1) Remove the flat plastic cover plates over the cell vent caps;
    2) Survey and mark where best to drill a hole in a cover plate that would allow a tube inserted through the hole access to gas under the plate, without damaging battery case or cell vent caps;
    3) Drill the hole;
    4)Replace covers, and tape their edges to secure them in place and to prevent gases escaping at edges;
    5) Insert snug-fitting plastic tube down through aforementioned hole in cover;
    6) Connect outer end of that tube to OEM vent tubing (including the 90° thing from the original battery);
    7) Tie tubing in place.
    I also added spacers to make the battery match the original space and bracket.
  15. nicoj36
    nicoj36 Active Member
    518
    162
  16. Mendel Leisk
    41,473
    3rd gen Prius hold-down bracket is a poor design, completely intolerant of the slightest height variation. I changed a battery on a matrix a few weeks back: same story. Luckily I had a washer in my change pocket, made it just work. Could have used a couple more.
    Wish they’d adopt the more conventional threaded rod and nut, with hook at the bottom.
    CR94 likes this.
  17. NewHybridOwner
    607
    283
    W. Michigan
    I have read that the quality of Optima batteries is not what it used to be. And I think they are more expensive than the OEM with their 7-yr (pro-rated) warranties.
  18. PriusII&C
    PriusII&C Active Member
    426
    144
    San Jose, California
    I did something similar to yours on a Harbor Freight 35 AH AGM battery. I thought the battery should have some built-in vent on its cover, and I should seal that vent. What puzzles me is I could not find it. Just wonder if you saw a built-in vent in its cover?
    CR94 likes this.
  19. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    That's the same battery, except the label. It does not come with a provision to connect a vent hose. If the cells vent gas (which should normally never occur with an AGM battery), they apparently intend it to escape through notches at the ends of the cover plate (besides which the edges probably aren't perfectly sealed, although they're a snug fit). I sealed those spots, along with the rest of the cover plate perimeter, with tape, in order to direct any gas out through my added vent tube.
    PriusII&C likes this.
  20. toolbox2014
    toolbox2014 Junior Member
    36
    central OC, CA
    Where do I buy an OEM battery? Dealer?
