What can I do with this?
Discussion in 'Gen 3 Prius Audio and Electronics' started by 102mm, Nov 30, 2013.
  1. .paul.
    .paul. Junior Member
    just gun it in reverse. that's what I do :LOL:
  2. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    Before entering the vehicle walk around back and give it a quick whip. Now you can be sure your not going to run over some baby. If you can not back into a parking spot using mirrors without the camera, then another...um...solution is required.
    Les_PL likes this.
  3. fuzzy1
    10,710
    My lower rear window and taillights are neither protected by aerodynamics nor fitted with washers or wipers, so must be frequently hand washed in my typical winter driving conditions. The camera lens gets cleaned at the same time.
    Our new Subaru, acquired last week to replace a previous century Subaru, is going to have the same issue.
  4. still in school
    still in school Junior Member
    28
    I can't believe what I'm reading
    uropip and Scynfewl like this.
  5. Scynfewl
    Scynfewl Junior Member
    Northern Virginia
    When driving a friends car I can't look at the display. You cant rely on it for anything more than distance to an object. For me trying to pay attention to normal views and the screen leads to not really focusing. Alsway end up stopping, taking that instant of time needed to forget the screen and continue.
    More on point most vehicles have rearview cameras now. Honda for one has them on all models and trim except Fit. They all are degraded by water on the lens. The only remedy I can come up with is to have the camera behind a surface in a rear wiper path. Which doesn't work well on sedans for camera placement not to mention lack of reaer wipers on vehicles.
  6. zebelkhan
    zebelkhan Member in good standing
    165
    38
    Morgan Hill, CA
    I also think there is a protective film on OP's camera lens that has not been removed. To those who think Toyota should have found a way to keep the lens clean, well, I suppose they could have installed a separate wiper for it but I doubt anyone would be willing to pay for it... :)
    Try cleaning the lens with rain-x. It will keep water and dust off the lens longer.
    Personally, I installed an aftermarket backup camera on mine just to have one (like most other MODs I have done) but I really find it useless, except for a quick glance to make sure there is nothing there out of my normal view. It does help a little with parallel parking as you can come very close to the car behind you without touching it, but that is about it.
  7. bisco
    52,858
    wiper/washer, but then, it would be covered in water again. maybe a clear flat cover that could have a small headlight wiper. shouldn't cost more than a thousand bucks or so.
  8. mrbigh
    3,686
    699
    Long Island, NY
    I had already suggested a fix for this problem, "get a maid".....
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Small? What? 1/8" long blade :rolleyes:
  10. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    A wiper isn't necessary. If a reasonably protected spot can't be located in wind tunnel testing, then a simple jet attached to the window washer system would suffice. It'd cost a tiny fraction of what the overall camera system already adds to the vehicle price.
  11. frodoz737
    4,805
    2,561
    33
    This is funny.
    uropip likes this.
  12. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I think that requiring cameras in cars is ridiculous, but if you're going to do it, do it right. It would be a trivial engineering exercise to fix the issue. Why bother with a wiper and spray on the rear window at all from your perspective? The camera is there because ostensibly the window is not adequate for visibility. If you can clean one, you might as well be able to clean both.
  13. zebelkhan
    165
    38
    Morgan Hill, CA
    I like the maid idea. I actually carry one in my trunk at all times.... :)
  14. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I have one, but she won't get in the trunk :mad:
    zebelkhan likes this.
  15. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    Mine doesn't want to get out from the trunk :eek:
  16. retired4999
    2,652
    627
    Eau Claire, Wi.
    Boy oh boy you guy's sure have problems, use HONEY! :D
    zebelkhan and Les_PL like this.
