What Can We (3rd gen) Learn from Updates Made to the 4th gen?
Discussion in 'Gen 3 Prius Main Forum' started by kyoo, Apr 19, 2017.
  1. bisco
    51,893
    i'm sure lowering would help. they also added more aero underneath, i believe.
  2. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Sorry to say that what I've learned is that I'm not going to buy a Gen IV Prius
    bisco and mmmodem like this.
  3. Tideland Prius
    16,553
    Alright after one page of chit chat, legitimately? Only a little since the advancements are in the engine and hybrid system (like redesigning the piston and intake to increase the tumble ratio of the air/fuel mixture)
    • Slightly lower the car for aerodynamics (the Gen 4 is 0.3" lower IIRC)
    • There are vortex generators near the base of the A-pillars where the mirrors are mounted to increase stability
    • There are fins on the taillight lens for aerodynamic flow (you'll need to figure out where to put them on the Gen 3 to improve air flow rather than make it worse)
    • Use wheel covers with fewer holes
    • Remove the rear wiper
    • (we already knew this one) Use foam pipe insulator to keep the engine warm in the winter.
    jerrymildred and kyoo like this.
  4. kyoo
    kyoo Junior Member
    40
    great post - thanks! Replace or remove the top antenna altogether? I think antennas are only for AM stations correct? though, come on that has to have like zero effect on MPG
  5. Tideland Prius
    16,553
    It's up to you lol. It's for AM/FM and there's also a satellite radio antenna in the base.
    Some have replaced it with a sharkfin antenna for the look. It does reduce AM/FM reception strength a bit.
  6. bisco
    51,893
    post #3 was not 'chit chat', but thanks for backing me up.:cool:
    Tideland Prius likes this.
  7. kyoo
    kyoo Junior Member
    40
    my b :)
    I think I read somewhere that the five with a performance package is lowered 1.1" in front and 1.3" in rear - can anyone confirm? may be a cheaper swap than aftermarket suspension I wonder if it's the shocks and springs or just springs - assuming just springs
  8. Tideland Prius
    16,553
    2011 Toyota Prius Offers All New PLUS Performance Package | Toyota
  9. bisco
    51,893
    that data is all in the original video's in the gen 4 stickies, but there's a lot of stuff there to look through trying to find it.
  10. kyoo
    kyoo Junior Member
    40
    got it - more for the sporty feel I guess then. good info all!
