what caused my 2008 package 5 touchscreen to crack
Discussion in 'Gen 2 Prius Technical Discussion' started by WWJD08, Sep 13, 2009.
  1. WWJD08
    WWJD08 New Member
    70
    Frederick, Colorado
    :( My wife told me that on the touchscreen when useing the climate display to adjust temp, the up and down arrows would not work, inside air flow and out side air would not work.
    I took it in to the dealership and they showed me the screen had a crack in it :eek: causing this problem. The car is 1 yr 2 months old and has 21k miles on it, so it still has a factory warranty.
    I was told that this is not covered under warranty:confused: I asked what would cause this to happen and was not given a reason . this costs $7600.00 to replace.
    Is there anyone else out there that has had this Problem?
  2. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    No Pun intended, was that $7,600.00 to replace??? That's close to 1/3 the cost of a vehicle!! Are they out of there mind??
    I would check around. The only reason I could think it would crack is someone accidentally hit it, or did something. I have had touchscreens for years and "never" had a problem with any of them.
    Something is not right for sure. Call your Rep.
  3. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Do a search on MFD Cracked. I see from other posts they were able to get a refurbished unit for less than 1,000.00. I did not find any reason for them to crack in the post, but it may be a cheaper alternative for you. I also saw that sometime they could be had on ebay.
    Good luck and if you get any info on "How" they crack would be interesting.
  4. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    If it got hit with something you may want to check with your car insurance and see if its covered under your comprehensive coverage, but at $7600 it may be worth it to have a "thief" break in and steal it while you are out at the movies to get it covered.
  5. northwichita
    481
    102
    29
    Wichita KS
    [/i]
    YouTube - Car Rental
    Your warranty question reminds me of a seinfeld episode. To paraphrase, you know how to take a warranty, you don't know how to honor your warranty, which is the most important part of the warranty.
    Perhaps call a toyota rep, the dealerships are owned independently.
