What causes a loud "clunking" sound when the engine shuts off?
Discussion in 'Gen 2 Prius Main Forum' started by wbs887700, Jul 14, 2021.
  1. wbs887700
    wbs887700 Junior Member
    74
    My 2006 Prius is starting to make a loud noise when the engine shuts off while it is parked in ready mode. Like, when I have the AC running while I'm parked for example, and the engine shuts off.... It doesn't always do it, but often it makes that loud noise, and it shakes the car noticeably, when it shuts off. It almost sounds/feels like a stick shift car when it stalls out.
    What could cause this? I keep getting nervous that it's going to damage something, and ironically this all started after I used Lucas oil stabilizer with one of my past oil changes (I have drained it since and don't use it anymore//). Lucas oil stabilizer increases the thickness of the oil.
    How can I fix this?
  2. privilege
    privilege Active Member
    659
    169
    Birmingham
    First guess:
    motor mounts
    additional guesses:
    exhaust hanger
    worn suspension
    sloppy bearing somewhere (internal, expensive)
    get a friend to turn it on/off and watch the engine... does it rotate 4-5" when the CLANG happens ?
  3. PriusCamper
    PriusCamper Senior Member
    13,426
    5,421
    Pacific Northwest, USA
    Atkinson engine's nature to have this glitch periodically...
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I noticed when my hybrid battery was getting ready to die it did not shut off or turn very elegantly. New battery much better.
    But many posts about bad motor mounts.
    what’s the deal with your hybrid battery is it the original?
  5. bradcarnage
    bradcarnage New Member
    Fresno, California
    Any update on this? I picked up an 06 prius here and it's starting to show signs of that same issue.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    My C does this too.
    Barely noticeable and not all the time.
    From the responses here, it would appear that it really is NOT an "issue" unless it gets
    really LOUD.
