What causes interior light to flash?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by DianaM, Mar 21, 2015.
  1. DianaM
    DianaM Junior Member
    Red Wing, MN
    2014 Prius c
    While driving tonight I was making a right turn and I heard two short beeps and my interior light flashed on and off two times. This happened three more times after stopping and when I put my foot on the gas again the interior light came on and then off again, no flashing or no beeps. Has this happened to anyone before and if so do you know why?
    I just hit my 16,000 mile mark on my 2014 Prius C two. Thanks in advance for any help.
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Is your key/fob being crushed in your pocket?
  3. DianaM
    Red Wing, MN
    2014 Prius c
    No key fob. My guess is it's a warning for something but I don't know what cause I didn't do anything different than I normally do. I tried looking it up in the manual and can't find anything.
  4. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    Possibly a problem with door (including hatch) switches or associated wiring?
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Door not closed tightly.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    I was going to say that a wire might be getting pinched with the change of weight vectors..........
    But a loose door latch is a MUCH more likely cause, or one of the door sensing switches.
    This might be a good test of whether your dealer's service department is competent or not.
    Seat belt stuck in door ??
  7. Mendel Leisk
    42,268
    Wearing a long dress? ;)
    DianaM likes this.
  8. AliIzad
    AliIzad Member
    170
    72
    Southern California
    This happened to me a couple of weeks ago; I had not properly closed the hatch door.
  9. DianaM
    Red Wing, MN
    2014 Prius c
    That's exactly what it was, the hatch door was not shut tightly. Thanks everyone for your responses. Problem solved.
    AliIzad likes this.
  10. bisco
    52,777
    now we know, thanks!
