What coolant/fluid to change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhman2006, Feb 11, 2018.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    My 2011 is getting close to 75K miles and I'm thinking about changing out the coolants. So far I've got transmission fluid, engine, and inverter coolants on my list. Is there anything else that I need to change? If not at 75K, at 100K?
  2. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    Brake fluid? You could check the reservoir for cloudy or darker fluid. It should be clear and light in color.
  3. douglasjre
    douglasjre Senior Member
    2,095
    701
    Null, NL
    HOAT. If you have too much water you will get a startup knock. No joke
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Toyota intended many of them to go for 120,000 miles.
    I would hold off the coolants until then, unless there is a reason.
    Brake fluid can be tested, I would test it before even reading up on the tricky ways to change it. (There is no simple way)
    amazon.com/Automotive-Diagnostic-Testing-Calibrated-Indicator/dp/B01EOD7INK
    I would consider draining and refilling the ATF WS in the transaxle every 90,000 miles
    Bay Stater likes this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,690
    Bay Area
    Coolant last to 120k miles, 75k is way too early. I would do the transmission fluids and check the brake fluids.
  6. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    +1 on the ATF! I did mine today at 120K for the second time. First time was at 50K. Owned the car since 40K.
    NutzAboutBolts and Raytheeagle like this.
