What coolant to buy?
Discussion in 'Gen 2 Prius Technical Discussion' started by enginestarter, Sep 10, 2019.
  1. enginestarter
    enginestarter Junior Member
    66
    UK
    Active
    I'm replacing the cooling inverter pump.
    In YouTube videos they say to top up the coolant.
    What should I buy?
    I looked in amazon (UK) and they cost about £5?
    Topping up is OK instead of draining and refilling?
    Thanks.
  2. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    You should use Toyota Super Long Life Coolant, or similar, like Zerex Asian, Peak Asian, or generally anything that says it's made for Asian manufacturers. Usually in the US, Zerex Asian is the cheapest.
    Skibob likes this.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Toyota SLLC (Super Long Life Coolant). Yes it's a good idea to drain your inverter loop and refill with fresh coolant.
    Skibob likes this.
  4. enginestarter
    66
    UK
    Active
    Guys, I had my inverter pump replaced today.
    I had help from my neighbour.
    I hadn't bought the coolant yet. He said topping up with water would be fine.
    Seems OK. But, I'm having serviced, so will drain and replace with coolant.
    I found 'Toyota Super Long Life Coolant' on ebay UK.
    How much do I need?
    I'm guessing 1 litre won't be enough. So I need 5 litres?
    I couldn't find 'Asian' specific. Any idea what I need in the UK?
    Thanks.
  5. frankv64
    frankv64 Junior Member
    23
    Colonia NJ
    Buy 2 gallons you won’t use all of it
    iPhone ? Pro
  6. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    I believe the total capacity of the system is 3 gallons US.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    The inverter loop is less than a gallon, more like probably a half gallon;).
    Buy the pink Super Long Life coolant(y).
    Skibob likes this.
  8. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    Right, sorry, forgot it was just the inverter. I was listing for both just because I'm getting ready to change both myself.
    Raytheeagle likes this.
