What could make a puff, puff sound?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Isaac Zachary, Jan 16, 2023.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,789
    1,506
    I noticed the other day there was a strange noise when we started going down a long decent. It sounded like steam puffing, maybe like water dripping on something hot. It was kind of randomly spaced out between puffs. It made one, then a couple seconds later another, then 4 or 5 seconds, then a couple, and so on.
    I hope it's water (there's been a lot of snow and ice) that started dripping on the hot exhaust. But it seemed to come from the back. The passengers in the back heard it coming from behind them and mainly from the side the battery intake vent is. Could this be the battery offgassing from not using a B mode? Battery was one bar lower from fully charged when this happened.
    PS. This was in my Avalon Hybrid, but I thought I'd post it here as it's a 2013 so I imagine the battery is similar to a 3rd gen Prius.
    52,904
    not using b mode would only affect your brake pads. maybe melting ice on muffler is a good theory
    Isaac Zachary likes this.
  3. Isaac Zachary
    2,789
    1,506
    I noticed when engine braking the battery doesn't charge as much. It charges like when taking your foot off the accelerator.
    Without engine braking (B mode) then using either brakes or the cruise control make the battery charge at a much higher rate.
    For the record, I was not riding the brakes, but rather using cruise control on a grade that it was enough to hold the vehicle back.
  4. ChapmanF
    19,060
    You've nailed the purpose of B mode exactly. It charges the battery less aggressively (which sometimes requires more use of the engine-as-vacuum-pump to burn off energy), which is useful if you know you will be on a long descent where the battery is going to be maxed out by the bottom anyway, and the lower charge rate at least goes easier on it.
  5. bisco
    52,904
    In 20 years, I’ve never gone down a descent long enough to matter
  6. fuzzy1
    10,723
    Come out west, you can take scenic mountain routes that will do it several times the same day.
  7. bisco
    52,904
    No doubt, but I’d fly and rent a gasser
  8. Isaac Zachary
    2,789
    1,506
    There are hills here that you can B mode the entire way down, not touching the brakes even once, and still end up with a full HV battery.
  9. ChapmanF
    19,060
    In "USA", no less!
  10. fuzzy1
    10,723
    Probably thousands of them. I've been down just dozens.
    ... and plenty where the foot brake is still required to hold down to safe speeds. I run into this every trip to and from dad's place.
  11. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    Plenty places in the East, too. Bisco needs to venture out of his neighborhood more.
    fuzzy1 likes this.
  12. bisco
    52,904
    Why?
    CR94 likes this.
  13. bisco
    52,904
    We’re 1400 miles from home, completely flat the whole drive
